[mapserver-users] Re: OSM2pgsql, latlong, OpenStreetMap data, uDig = weird projection
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Mar 16 11:01:28 EDT 2010
At least uDig 1.2 M9 milestone version does support Google Mercator as
EPSG:900913.  However, there are more alternatives.  QGis and OpenJUMP,
for example. You can also add more supported output projections to your
WEB METADATA and LAYER METADATA sections in the mapfile as a space
limited list and you are not limited to use just that one projection.
 "wms_srs"    "EPSG:3067 EPSG:2393 EPSG:4326 EPSG 900913"
OpenJUMP gives much better user interface for selecting SRS and output
format than uDig. It does not zoom automatically to WMS layer so open
some vector data in the project first. You can also try Right click -
Zoom to WMS layer but it does not necessarily work because Mapserver is
sending only lat/long bounding box and one projected bounding box to
zoom in.
-Jukka Rahkonen-
Mulone wrote:
> Thanks for your reply.
> Yes, I tried to visualise the WMS server on uDig, but
> apparently it doesn't
> support the Google Mercator proj.
> Is there another way of checking the wms data?
> Cheers!
> Mulone
> PhD student
> http://n2.nabble.com/OSM2pgsql-latlong-OpenStreetMap-data-uDig
> -weird-projection-tp4736654p4744064.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
