[mapserver-users] Forcing WMS errors in XML-format
in PHP-MapScript
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue Mar 16 13:05:11 EDT 2010
On 2010-03-16 14:05, Daniel Morissette wrote:
> Jan Hartmann wrote:
>> This is probably something I should try to look up myself, but
>> perhaps someone on this list has a quick answer.
>> I'm generating WMS output completely from PHP MapScript
>> (essentially to make non-projected raster files available for WMS
>> clients under a fake projection number, to georeference raw
>> coordinates). If something goes wrong with the getCapabilities
>> request, I would like to output a valid XML error string that can be
>> understood by regular WMS clients. Any pointers to documentation on
>> the required/optional XML formats?
> I guess the best reference will be the WMS spec document itself, for
> the version of WMS that you are implementing. The spec docs are
> available at http://www.opengeospatial.org/standards/wms
> If you look at the WMS 1.1.1 doc from that list, section 6.7 discusses
> service exceptions and Annex A contains the XML exception DTD as well
> as an exception example.
> Dnaiel
The DTD in this document is validated as
"http://www.digitalearth.gov/wmt/xml/exception_1_1_0.dtd". This site has
been renamed www.digitalearth.org
(http://trac.osgeo.org/mapserver/ticket/659) six years ago, but even
that location doesn't exist anymore. Where do I find the DTD?
Jan
