[mapserver-users] MapServer 5.6.2 released
Daniel Morissette
dmorissette at mapgears.com
Sat Mar 20 12:44:13 EDT 2010
The MapServer team is pleased to announce the release of MapServer
version 5.6.2.
No new functionality has been added. This is a maintenance release that
fixes a few important issues found in 5.6.0 and 5.6.1 The list of fixes
since 5.6.1 is included at the end of this message.
The source code is available at:
http://mapserver.org/download.html
The binary distributions listed in the download page should be updated
with the new release in the next few days.
Version 5.6.2 (2010-03-20):
- Check error returns from mapstring functions (#2988)
- Correct mutex locking problem with rasters with no inherent georef.
(#3368)
- Fixed problem with isValidItem vs OGR special attributes (#3356)
- Support wrap character for SVG output (#3367)
- Fixed msMSSQL2008CloseConnection() to free the statement handle
properly (#3244)
- Fixed PHP MapScript's metadata.nextkey() that was sometimes skipping some
entries on first call because the NULL arg was not properly handled
(#3363)
- Fixed the query handling with the MSSQL2008 driver (#3058)
- Fixed swig zoomRectangle() method: the maxy in the rect object have to
be < miny value (#3286)
- Backport fix for SLD filters column names detection (#3052)
- Backport fix for WFS OGC filters regex tests (#3289)
- Fix crash with GRID layers with no classes (#3352)
- Avoid memory error when building SQL bbox (#3324)
- Determine PgSQL version in a more backwards compatible way (#3291)
- Implemented RFC 52 LayerResultsGetShape support for OGR connection
type. (#3069)
- Fixed problem with the oracle driver w/FUNCTION=NONE (#3260)
- Got rid of invalid warning about missing EPSG proj in WMS GetCapabilities
when map has a valid EPSG proj, but layer doesn't (#2028)
- Correct one pass query problems and OGC filter query (#3305)
- Correct QueryByOperator (#3346)
