[mapserver-users] Map file xsl transformation and regular
expressions
Alan Boudreault
aboudreault at mapgears.com
Mon Mar 22 12:04:09 EDT 2010
Alexandre, could you test the new xsl file and see if your two issues have
been fixed. You can get it via:
http://trac.osgeo.org/mapserver/browser/trunk/mapserver/xmlmapfile/mapfile.xsl?format=raw
I did a quick fix to integrate it in MS 5.6.3, which is supposed to be
released today.
expression/filter examples:
<expression type="CONSTANT">583</expression> or <expression>583</expression>
will be quoted.
<expression type="REGEX">/.../</expression> and
<expression type="MSEXPR">(...)</expression> will not be quoted.
symbol examples:
<symbol type="NAME">star.gif</symbol> will be quoted
<symbol type="ID">32</symbol> will not be quoted
Thanks,
Alan
On March 19, 2010 02:59:17 pm Alexandre Soares wrote:
> The symbol attribute (which does not get quoted by default) causes a
> problem if the value references a stmbol's name. I think it could also
> benefit from your fix.
> Thank you!
> On Fri, Mar 19, 2010 at 2:49 PM, Alan Boudreault
> <aboudreault at mapgears.com>wrote:
> > Alexandre, you are right, if the expression is an regular expression, it
> > shouldn't be quoted. I think the only solution would be to add an
> > attribute in
> > the xml schema, that will specify if the expression is an regular
> > expression
> > of not. Something like:
> > <expression regex="ON"></expression>
> > In this case, the xsl transformation would not quote it. I take a note on
> > that
> > and should fix this in the next few days.
> > Thanks for reporting!
> > Alan
> > On March 19, 2010 02:21:45 pm Alexandre Soares wrote:
> > > Hi,
> > > When I transform my xml map file to a map file, my expressions that
> > contain
> > > a regular expression (the same is true for filters) are rendered with
> > > double quotes (because the stylesheet has the quote="1" param for
> > > those templates).
> > > Is there an intended way to achieve this? I know I could modify the
> > > stylesheet to not quote those elements and then quote-wrap my value if
> > > I need them (in case of string comparison).
> > > Thank you!
> > Alan Boudreault
> > Mapgears
> > http://www.mapgears.com
Alan Boudreault
Mapgears
