[mapserver-users] Re: mapserver not generating proper map
sunny74
sb.ray at hotmail.com
Mon Mar 22 15:31:20 EDT 2010
Hi BrainDrain,
Thanks for your reply.
Your solution doesn't work.
the code relating to the info control is the culprit.
It started giving errors, then I commented it but after that the map was not
getting displayed.
Finally after a lot of effort I got the map but with problems stated
earlier.
After applying your code I find that the background is occupying 600 * 600
but the actual layers are coming small even though magnification level is 6
or more.
I think it is Openlayer 2.8 which is causing the problem.So I need to go
back to OL2.7.
But then is it possible to hav Get Feature Info in 2.7 from shape files?
If you know how to do it pls send code across.
View this message in context: http://n2.nabble.com/mapserver-not-generating-proper-map-tp4776875p4779918.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
