[mapserver-users] Cannot get my layer to render via WMS...
mapper99
info at laudontech.com
Wed Mar 24 01:18:49 EDT 2010
Here is a map file I have:
MAP
NAME "WMSTEST"
EXTENT -91.409324 40.696301 -90.942253 41.074178
SIZE 800 600
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:4326"
END
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
"wms_title" "WMS Test Server" ##required
"wms_onlineresource"
"http://localhost:8080/cgi-bin/mapserv.exe?map=testwms.map&" ##required
"wms_srs" "EPSG:4326" ##recommended
END
END
LAYER
NAME "test"
METADATA
"wms_title" "TestLayer" ##required
END
PROJECTION
"init=epsg:4326" ##recommended
END
STATUS ON
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "host=127.0.0.1 port=5432 dbname=MarkGIS user=postgres
password=theguy"
DATA "geog FROM test USING SRID=4326 USING UNIQUE gid"
CLASSITEM 'cousubfp00'
CLASS
NAME 'default'
EXPRESSION ''
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 106 72 44
END
END
CLASS
NAME 'cousubfp00 = 90207'
EXPRESSION '90207'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 130 86 84
END
END
CLASS
NAME 'cousubfp00 = 90401'
EXPRESSION '90401'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 160 64 74
END
END
CLASS
NAME 'cousubfp00 = 90813'
EXPRESSION '90813'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 137 230 122
END
END
CLASS
NAME 'cousubfp00 = 90887'
EXPRESSION '90887'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 84 173 118
END
END
CLASS
NAME 'cousubfp00 = 90888'
EXPRESSION '90888'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 149 106 236
END
END
CLASS
NAME 'cousubfp00 = 91347'
EXPRESSION '91347'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 31 170 38
END
END
CLASS
NAME 'cousubfp00 = 91401'
EXPRESSION '91401'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 64 29 27
END
END
CLASS
NAME 'cousubfp00 = 92010'
EXPRESSION '92010'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 176 211 126
END
END
CLASS
NAME 'cousubfp00 = 92112'
EXPRESSION '92112'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 116 167 107
END
END
CLASS
NAME 'cousubfp00 = 92906'
EXPRESSION '92906'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 164 26 212
END
END
CLASS
NAME 'cousubfp00 = 92924'
EXPRESSION '92924'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 94 224 133
END
END
CLASS
NAME 'cousubfp00 = 93390'
EXPRESSION '93390'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 246 101 186
END
END
CLASS
NAME 'cousubfp00 = 94080'
EXPRESSION '94080'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 161 96 208
END
END
CLASS
NAME 'cousubfp00 = 94203'
EXPRESSION '94203'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 218 17 190
END
END
CLASS
NAME 'cousubfp00 = 94488'
EXPRESSION '94488'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 93 61 209
END
END
CLASS
NAME 'cousubfp00 = 94658'
EXPRESSION '94658'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 200 70 144
END
END
CLASS
NAME 'cousubfp00 = 94803'
EXPRESSION '94803'
STYLE
SYMBOL 0
OUTLINECOLOR 0 0 0
COLOR 45 32 194
END
END
CLASS
OUTLINECOLOR 32 32 32
END
END
END
If I use this URL:
http://localhost:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/mapfiles/testwms.map&layer=test&mode=map
The map draws fine. If I try and consume this map via a WMS client like
QGIS, the data does not draw. GetCapabilities appears to be fine:
http://localhost:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/mapfiles/testwms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
returns:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
<!-- MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>WMS Test Server</Title>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://localhost:8080/cgi-bin/mapserv.exe?map=testwms.map&"/>
<ContactInformation>
</ContactInformation>
</Service>
<Capability>
<Request>
<GetCapabilities>
<Format>application/vnd.ogc.wms_xml</Format>
<DCPType>
<HTTP>
<Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://localhost:8080/cgi-bin/mapserv.exe?map=testwms.map&"/></Get>
<Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://localhost:8080/cgi-bin/mapserv.exe?map=testwms.map&"/></Post>
</HTTP>
</DCPType>
</GetCapabilities>
<GetMap>
<Format>image/gif</Format>
<Format>image/png</Format>
<Format>image/png; mode=24bit</Format>
<Format>image/jpeg</Format>
<Format>image/vnd.wap.wbmp</Format>
<Format>image/tiff</Format>
<Format>image/svg+xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetMap>
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetFeatureInfo>
<DescribeLayer>
<Format>text/xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</DescribeLayer>
<GetLegendGraphic>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetLegendGraphic>
<GetStyles>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetStyles>
</Request>
<Exception>
<Format>application/vnd.ogc.se_xml</Format>
<Format>application/vnd.ogc.se_inimage</Format>
<Format>application/vnd.ogc.se_blank</Format>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
RemoteWFS="0"/>
<Layer>
<Name>WMSTEST</Name>
<SRS>EPSG:4326</SRS>
<LatLonBoundingBox minx="-91.4093" miny="40.6963" maxx="-90.9423"
maxy="41.0742" />
<BoundingBox SRS="EPSG:4326"
maxy="41.0742" />
<Layer queryable="0" opaque="0" cascaded="0">
<Name>test</Name>
<Title>TestLayer</Title>
<LatLonBoundingBox minx="-3.40282e+038" miny="-3.40282e+038"
maxx="3.40282e+038" maxy="3.40282e+038" />
<Style>
<Name>default</Name>
<Title>default</Title>
<LegendURL width="161" height="329">
xlink:type="simple"
xlink:href="http://localhost:8080/cgi-bin/mapserv.exe?map=testwms.map&version=1.1.1&service=WMS&request=GetLegendGraphic&layer=test&format=image/png&STYLE=default"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
But nothing draws in the map? What am I doing wrong here?
View this message in context: http://n2.nabble.com/Cannot-get-my-layer-to-render-via-WMS-tp4789195p4789195.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
