[mapserver-users] WMS GetFeatureInfo on a WFS layer
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Mar 25 09:55:14 EDT 2010
Hi Yves,
 Couple of things:
  First of all, you you should be able to do a GetFeatureInfo request on
this WFS layer. There is a bug with latest versions of MapServer I
believe trink and possibly 5.6 (I only test trunk). The bug is described
at http://trac.osgeo.org/mapserver/ticket/3403, and It should now be
fixed in svn. If you are builiding aginst trunk, please give it a try.
 Other notes on
   - I usually have a  "ows_latlonboundingbox" set on the wfs layer
   - I usually add &RADIUS=2 when doing a GetFeatureInfo request.
hope it helps.
best regards,
Yves Jacolin wrote:
> Hi Arnd,
> Thanks for your answer We will try an other way.
> The 2nd given url is really a WFS server, I successfully send a
> GetFeature request with filter parameter. :)
> Thanks again,
> Y.
> 2010/3/24 Arnd Wippermann <arnd.wippermann at web.de
> <mailto:arnd.wippermann at web.de>>
>     Hi,
>     as I know, you cann't request a WMS or WFS through a connection in
>     your mapfile (results to "Search return no result"). Only with own
>     data added as shapefile and so on, you can get a result for
>     GetfeatureInfo requests. Wether mapinfo via ogr cann't request, i
>     have no clue. But I would think, it should be possible.
>     I have checked, that the url is a valid wfs server, also it seems,
>     that it points to a wms server.
>     Arnd
>     *Von:* mapserver-users-bounces at lists.osgeo.org
>     <mailto:mapserver-users-bounces at lists.osgeo.org>
>     [mailto:mapserver-users-bounces at lists.osgeo.org
>     <mailto:mapserver-users-bounces at lists.osgeo.org>] *Im Auftrag von
>     *Yves Jacolin
>     *Gesendet:* Mittwoch, 24. März 2010 10:24
>     *An:* mapserver-users
>     *Betreff:* [mapserver-users] WMS GetFeatureInfo on a WFS layer
>     Hi,
>     I added a WFS layer in my mapfile and I am using MapServer as a
>     WMS server. I would like to send a GetFeatureInfo request on this
>     WFS layer but I always get a "Search return no result" as answer.
>     Is it possible to request such layer? I get same problem with an
>     OGR connection (mapInfo file). Does the problem could occur only
>     with a polyline feature if we click always too far of the feature?
>     Or the problem occur from the WFS service?
>     The WFS service I want to request in my WMS service is
>     http://carto.ecologie.gouv.fr/MEDD/wms.php?service_idx=17W&map=sacarte.map
>     <http://carto.ecologie.gouv.fr/MEDD/wms.php?service_idx=17W&map=sacarte.map>
>     Thanks in advance for your help,
>     Y.
>     Yves Jacolin
>     Responsable Formation et Support
>     Camptocamp France SAS
>     Savoie Technolac, BP 352
>     73377 Le Bourget du Lac Cedex
>     Tel : + 33 (0)4 79 26 57 97
>     http://www.camptocamp.com
>     yves.jacolin at camptocamp.com <mailto:yves.jacolin at camptocamp.com>
> Yves Jacolin
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
