[mapserver-users] PHP MapScript: shape->classindex is always 0
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Thu Mar 25 10:41:55 EDT 2010
Hi Alan
Thynk you for your support!
I've files http://trac.osgeo.org/mapserver/ticket/3406 and attached all
files necessary to reproduce the problem. Due to the current slowness of
the OsGeo the bug is filed twice, I've marked 3404 as a duplicate, sorry
for the annoyance.
Regards,
Peter
Alan Boudreault wrote:
> Hi Peter,
> If you are sure that the shape use the different classes you specified in the
> mapfile (you probably see it in your map image), so I guess it could be a bug.
> Please fill a ticket with a test case. Assign it to "aboudreault".
> regards,
> Alan
> On March 24, 2010 06:38:49 am Peter Hopfgartner wrote:
>> Hello
>> As I interpreted this, classindex should point to the right class of the
>> instantiated shape. Unfortunatly, classindex is always 0.
>> As a test I have a LAYER with 2 classes,
>>     CLASS
>>        NAME 'class1'
>>        EXPRESSION (([class] eq 1))
>>        STYLE
>>          SYMBOL "circle"
>>          SIZE 7.0
>>          OUTLINECOLOR 0 0 0
>>          COLOR 0 128 0
>>        END
>>     END
>>     CLASS
>>        NAME 'class2'
>>        EXPRESSION (([class] eq 2))
>>        STYLE
>>          SYMBOL "circle"
>>          SIZE 7.0
>>          OUTLINECOLOR 0 0 0
>>          COLOR 0 0 128
>>        END
>>     END
>> In the PostGIS database are 4 point, 2 with class=1 and 2 with class=2,
>> the generated map image shows the expected colors.
>> The following script:
>> <?php
>> $mapfile = 'test.map';
>> $map = ms_newmapobj($mapfile);
>> $layer = $map->getLayerByName('test');
>> $status = $layer->open();
>> $status = $layer->whichShapes($map->extent);
>> while ($shape = $layer->nextShape())
>>    echo "index: {$shape->index}\tclassindex: {$shape->classindex}\n";
>> $layer->close();
>> the following output:
>> index: 0    classindex: 0
>> index: 1    classindex: 0
>> index: 2    classindex: 0
>> index: 3    classindex: 0
>> which is not what I expected.
>> Am I missing something obvious or is this a MapServer bug?
>> Regards,
>> Peter
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax  : +39 0473 069902
www  : http://www.r3-gis.com
XING : http://www.xing.com/go/invita/8917535
