[mapserver-users] php mapscript
Sven Schroeter schroeter at netgis.de
Thu Mar 25 10:52:12 EDT 2010
Alan,
thanks for the reply, I tried it with getFeature(), but there comes the same
error.
nextShape() works only after msWhichShapes and here I need a rectobj.
But I want to use the script for queryByShape and queryByAttributes too.
Why there comes no array in $attr = $shpobj->values; ?
Any idea?
Sven
----- Original Message -----
From: "Alan Boudreault" <aboudreault at mapgears.com>
To: <mapserver-users at lists.osgeo.org>
Cc: "Sven Schroeter" <schroeter at netgis.de>
Sent: Thursday, March 25, 2010 2:32 PM
Subject: Re: [mapserver-users] php mapscript
> Sven,
> getShape() is deprecated. Use rather getFeature(). I suggest to also take
> a
> look at the nextShape() function:
> http://mapserver.org/mapscript/php/index.html#layerobj-class
> Alan
> On March 25, 2010 09:18:50 am Sven Schroeter wrote:
>> Hi,
>> I have an old php mapscript code that works fine with mapserver 5.02 or
>>  5.2, but not with 5.6.1.
>> The code runs an attribute tabe from a postgis layer and different querys
>> i.e. queryByRect:
>> @$datQuery = $query_layer->queryByRect($qRect);
>>  //number of objects
>>  $resnum = $query_layer->getNumResults();
>>  echo "number of objects: ".$resnum."<br>";
>>  //if query success
>> if ($datQuery == MS_SUCCESS) {
>>   $query_layer->open();
>>   //first row
>>   $result = $query_layer->getResult(0);
>>   $shpobj =
>> $query_layer->getShape($result->tileindex,$result->shapeindex);
>>   //read attribute
>>   //write headline
>>   echo '<table cellspacing="0" cellpadding="2" border="1" ><tr>';
>>   foreach($attr as $name=>$wert) {
>>    echo '<td bgcolor="#CCCCCC">'.$name.'</td>';
>>   echo '</tr>';
>>   //write datasets
>>   for ($j=0; $j<$query_layer->getNumResults(); $j++) {
>>    $result = $query_layer->getResult($j);
>>    $shpobj =
>>  $query_layer->getShape($result->tileindex,$result->shapeindex); $ri =
>>  $result->tileindex;
>>    $si = $result->shapeindex;
>>    echo '<tr id="row'.$si.'" >';
>>     echo '<td>'.$wert.'</td>';
>>    echo '</tr>';
>>    $shpobj->free();
>>   $query_layer->close();
>>   echo '</table>';
>> } // end success
>> In ms 5.6.1 the query is also successful (I get the correct number of
>> objects) but there comes following warning:
>> Invalid argument supplied for foreach() in ... Fatal error: Call to a
>>  member function free() on a non-object in ...
>> No object? Why? What has changed?
>> Thanks
>> Sven
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
