[mapserver-users] Re: ODBC OGR MS SQL CONNECTION
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 31 02:46:33 EDT 2010
ibrahimsaricicek wrote:
> I've changed like this
> CONNECTION "
> <OGRVRTDataSource>
> <OGRVRTLayer name='Araclar'>
> <SrcDataSource>ODBC:webuser/webuser at MsSql,AracView</SrcDataSource>
> <SrcSQL>SELECT * FROM AracView</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding='PointFromColumns' x='LONGITUDE'
> y='LATITUDE'></GeometryField>
> </OGRVRTLayer>
> </OGRVRTDataSource>"
> And result;
> msDrawMap(): Image handling error. Failed to draw layer named 'Araclar'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
> `Araclar'. Parse error at EOF, not all elements have been closed, starting
> with SrcDataSource
> Is there a problem while using comma?
Ibrahim,
I vaguely recall that if you do not include a DATA statement declaring the
layer you want to operate from OGR, then the connection string is parsed
using a comma to identify the layer. So try your existing connection
string, but add:
DATA "Araclar"
and see if that helps.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
