[mapserver-users] WCS 1.0 vs 1.1 image shifted
Ben Tuttle
benjamin.tuttle at gmail.com
Mon May 3 13:36:53 EDT 2010
Sorry for missing the previous discussion.
I do have a mapfile, data, and requests that result in offset grids
being returned.
I will re-read the spec once more before filing a ticket, but seems
strange (although not impossible) to me that the expected result would
be a grid that is shifted compared to the original data.
Would this still be the appropriate place to file the ticket?
http://trac.osgeo.org/mapserver/
Thanks for the help.
On Mon, May 3, 2010 at 8:19 AM, Lime, Steve D (DNR)
<Steve.Lime at state.mn.us> wrote:
> Like I said in the referenced message, I thought all was well in this regard. We'd need a good test case (data, mapfile, 1.0/1.1 requests) attached to a ticket. If there's a difference in the pixel models between WCS 1.0 and 1.1 then a request that differs only in version might be expected to generate slightly different output. I haven't looked at those specs in a good while though.
> Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Roger André [randre at gmail.com]
> Sent: Sunday, May 02, 2010 11:45 AM
> To: Ben Tuttle
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] WCS 1.0 vs 1.1 image shifted
> Hi Ben,
> I think it's a bug, at least based on the conversation that took place last year with Steve Lime regarding this - http://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg06123.html
> I'm not sure what the current state is of this though.
> Roger
> On Fri, Apr 30, 2010 at 1:18 PM, Ben Tuttle <benjamin.tuttle at gmail.com<mailto:benjamin.tuttle at gmail.com>> wrote:
> I am trying to understand the results I am getting from WCS requests
> to MapServer.
> If I make the same request changing only the WCS version the images I
> get back are shifted by 1 pixel in the x and y directions. A request
> for VERSION=1.1.0 gives me the image I expect while VERSION=1.0.0
> gives me back an image shifted by 1 pixel in the x and y directions to
> the North and West.
> The underlying data and mapfile are the same in both cases. So I am
> not sure if this is perhaps a MapServer bug or if perhaps I am reading
> the WCS spec incorrectly and this is actually the intended result (I
> hope it's not). Can anyone help me out?
> Request Examples:
> http://map.ngdc.noaa.gov/cgi-bin/mapserver/test_image_ms_wcs100_avgvis42_23_47_28.tif?map=../../../nfs/gisdata/mapserver/gcv4/index.map&request=GetCoverage&service=WCS&COVERAGE=F162008_v4_avg_vis&crs=EPSG:4326&VERSION=1.0.0&format=geotiff&resx=0.0083333333&resy=0.0083333333&bbox=42,23,47,28
> http://map.ngdc.noaa.gov/cgi-bin/mapserver/test_image_ms_wcs110_avgvis42_23_47_28.tif?map=../../../nfs/gisdata/mapserver/gcv4/index.map&request=GetCoverage&service=WCS&COVERAGE=F162008_v4_avg_vis&crs=EPSG:4326&VERSION=1.1.0&format=geotiff&resx=0.0083333333&resy=0.0083333333&bbox=42,23,47,28
> System Details:
> MapServer version 5.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
> INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Red Hat Enterprise Linux Server release 5.5 (Tikanga)
> Cheers, Ben Tuttle
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Cheers, Ben Tuttle
