[mapserver-users] Difference in GD vs AGG PNG output -- seams in
my shape files.
Dane Springmeyer
blake at hailmail.net
Tue May 4 02:37:12 EDT 2010
You might try setting a map background color the same as your ocean
color used for the polygons.
Dane
On May 3, 2010, at 2:03 PM, Mark Deneen wrote:
> Steve,
> I had just tried adding an outline before I received this message. It
> helps, but at the expense of my coastline. This is, however, not a
> terrible issue because you can still see the detail as you zoom in
> further.
> Thanks,
> Mark
> On 5/3/2010 4:38 PM, Lime, Steve D (DNR) wrote:
>> You may be seeing some deficiencies in the analytical AA algorithm
>> AGG uses. I remember reading about it awhile back in discussions
>> about alternative algorithms and recall it being prominent with
>> vertical edges. Have you tried setting an outline color to the same
>> value as your fill color? That may help.
>> Steve
>> ________________________________________
>> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org
>> ] On Behalf Of Mark Deneen [mdeneen at gmail.com]
>> Sent: Monday, May 03, 2010 2:42 PM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Difference in GD vs AGG PNG output --
>> seams in my shape files.
>> Hi,
>> I recently upgraded from 5.2.x to 5.6.1, and from GD to AGG.
>> Here is my output:
>> AGG: http://i44.tinypic.com/5oh261.png
>> GD: http://i39.tinypic.com/2h4j409.png
>> Visual Representation of the shapefile: http://i44.tinypic.com/1zz2u76.png
>> Look north of Cancun -- the AGG driver is showing seams where the
>> polygons connect in my shape file. It doesn't do it for all of
>> them, but I see it a lot, especially when the seams are not
>> straight N/S or E/W. I feel that it has something to do with AGG's
>> antialiasing, but I've not been able to pin it down.
>> Is there any way to resolve this? I'd really like to use the AGG
>> driver, I love the output it produces, minus the white lines!
>> Mark
