[mapserver-users] invalid schema location?
bartvde at osgis.nl
bartvde at osgis.nl
Tue May 4 04:52:20 EDT 2010
Hi Roy,
I can confirm the issue with Xerces. It should be as simple as replacing
the space with %20 or not?
Fatal Error at (file stdin, line 8, char 361): The schemaLocation
attribute does not contain pairs of values.
Can you open up a ticket in the Mapserver Trac?
Best regards,
Bart
> Thanks,
> I tested it, but with a post message and a GetFeature as xml body
> mapserver keeps responding with a invalid schema (with spaces).
> Even without a outputformat in the getFeature.
> Is this bug going to be solved in a next version of mapserver?
> Roy
> _____
> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
> To: Roy Braam [mailto:roybraam at b3partners.nl],
> mapserver-users at lists.osgeo.org
> Sent: Mon, 26 Apr 2010 15:27:48 +0200
> Subject: Re: [mapserver-users] invalid schema location?
> Hi,
> I inspired to compare how Mapserver and Geoserver are handling this
> thing. At least I can say that they are doing thing in a bit different
> way, and Geoserver is creating alwayd the DescribeFeatureType URL in the
> GetFeature output without OUTPUTFORMAT.
> GEOSERVER
> - GetFeature with WFS version 1.1.0 and outputformat=gml2
> -> RESULT schema location contains
> "...geoserver/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=..."
> So the GetFeature was done with version 1.1.0 but the URL to schema
> location is containing "version=1.0.0", and because WFS 1.0.0 default is
> gml2 this is giving a correct schema.
> - GetFeature with WFS version 1.1.0 and outputformat=text/xml;
> subtype=gml/3.1.1
> "...geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=..."
> Now the schema location URL is using "version=1.1.0" which defaults to
> gml3.1.1 and schema is correct.
> MAPSERVER
> On the other hand, Mapserver version 5.2.1 behaves this way
> GetFeature request wioth WFS version 1.1.0 and outputformat=gml2
> (here is part of my test request literally:
> &service=wfs&version=1.1.0&request=getfeature&typeName=test&maxfeatures=2&OUTPUTFORMAT=gml2)
> /cgi-bin/wfstest?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=test&OUTPUTFORMAT=XMLSCHEMA">
> Running this DescribeFeatureType query returns schema with reference to
> "http://schemas.opengis.net/gml/2.1.2/feature.xsd"
> Features in the GetFeature are in gml2 format.
> I suppose this is working OK.
> Request WFS version 1.1.0 and outputformat=text/xml; subtype=gml/3.1.1
> (&service=wfs&version=1.1.0&request=getfeature&typeName=test&maxfeatures=2&OUTPUTFORMAT=text/xml;
> subtype=gml/3.1.1)
> This does not work at all for me. Mapserver is returning features in
> gml2 format with this parameter, even if I am specially asking for
> gml3.1.1
> Request WFS version 1.1.0 and without using outputformat at all (WFS
> 1.1.0 default is text/xml; subtype=gml/3.1.1)
> - > schema location contains
> cgi-bin/wfstest?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=test&OUTPUTFORMAT=text/xml;
> subtype=gml/3.1.1
> Running this query returns schema with reference to
> "http://schemas.opengis.net/gml/3.1.1/base/gml.xsd"
> Features in the GetFeature are in gml 3.1.1. format.
> I suppose this is working OK. However, Mapserver does not need
> OUTPUTFORMAT parameter here but the result is the same even if I leave
> it out.
> -Jukka Rahkonen-
> _____
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Roy Braam
> Lähetetty: 26. huhtikuuta 2010 14:26
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] invalid schema location?
> Hello List,
> When i do a WFS getFeature request mapserver returns a xml that starts
> with:
> <?xml version='1.0' encoding="ISO-8859-1" ?>
> <wfs:FeatureCollection
> xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:wfs="http://www.opengis.net/wfs"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
> http://server.nl/geoservices/aankoopgebieden?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=LL&OUTPUTFORMAT=text/xml;
> subtype=gml/3.1.1 http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> numberOfFeatures="16">
> <gml:boundedBy>
> If i read this site:
> http://www.w3.org/TR/xmlschema-0/#schemaLocation
> the schema locations needs to be "pairs of URI references, separated
> by white space".
> Because the OUTPUTFORMAT="text/xml; subtype=gml/3.1.1" a space is in
> the url of the first pair in my example.
> 1) spaces are not valid in URLS??
> 2) you don't have pairs anymore. You have a odd number of values if
> you separate by space...
> So, is mapserver generating a invalid XML?? Or i'm doing something
> wrong....
> Version of mapserver = 5.6.3
> Roy _______________________________________________
