Re: [mapserver-users] invalid schema location?
Roy Braam roybraam at b3partners.nl
Tue May 4 05:39:17 EDT 2010
Hi Bart,
I opened a ticket:
http://trac.osgeo.org/mapserver/ticket/3447
Roy
  _____
To: Roy Braam [mailto:roybraam at b3partners.nl]
Cc: Rahkonen Jukka [mailto:jukka.rahkonen at mmmtike.fi], mapserver-users at lists.osgeo.org
Sent: Tue, 04 May 2010 10:52:20 +0200
Subject: Re: [mapserver-users] invalid schema location?
Hi Roy,
  I can confirm the issue with Xerces. It should be as simple as replacing
  the space with %20 or not?
  Fatal Error at (file stdin, line 8, char 361): The schemaLocation
  attribute does not contain pairs of values.
  Can you open up a ticket in the Mapserver Trac?
  Best regards,
  Bart
  > Thanks,
  > I tested it, but with a post message and a GetFeature as xml body
  > mapserver keeps responding with a invalid schema (with spaces).
  > Even without a outputformat in the getFeature.
  > Is this bug going to be solved in a next version of mapserver?
  > Roy
  >   _____
  > From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
  > To: Roy Braam [mailto:roybraam at b3partners.nl],
  > Sent: Mon, 26 Apr 2010 15:27:48 +0200
  > Hi,
  > I inspired to compare how Mapserver and Geoserver are   handling this
  > thing.  At least I can say that they are doing thing in a bit   different
  > way, and Geoserver is creating alwayd the DescribeFeatureType   URL in the
  > GetFeature output without OUTPUTFORMAT.
  > GEOSERVER
  > - GetFeature with WFS version 1.1.0 and   outputformat=gml2
  >  -> RESULT schema location contains
  > "...geoserver/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=..."
  > So the GetFeature was done with version 1.1.0 but the   URL to schema
  > location is containing "version=1.0.0", and because WFS 1.0.0   default is
  > gml2 this is giving a correct schema.
  > - GetFeature with WFS version 1.1.0 and   outputformat=text/xml;
  > subtype=gml/3.1.1
  > "...geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=..."
  > Now the schema location URL is using "version=1.1.0"   which defaults to
  > gml3.1.1 and schema is correct.
  > MAPSERVER
  > On the other hand, Mapserver version 5.2.1 behaves this   way
  > GetFeature request wioth WFS version 1.1.0 and   outputformat=gml2
  >     (here is part of my test request   literally:
  > &service=wfs&version=1.1.0&request=getfeature&typeName=test&maxfeatures=2&OUTPUTFORMAT=gml2)
  > /cgi-bin/wfstest?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=test&OUTPUTFORMAT=XMLSCHEMA">
  > Running this DescribeFeatureType query returns schema   with reference to
  > "http://schemas.opengis.net/gml/2.1.2/feature.xsd"
  > Features in the GetFeature are in gml2   format.
  > I suppose this is working OK.
  > Request WFS version 1.1.0 and outputformat=text/xml;   subtype=gml/3.1.1
  >        (&service=wfs&version=1.1.0&request=getfeature&typeName=test&maxfeatures=2&OUTPUTFORMAT=text/xml;
  >   subtype=gml/3.1.1)
  > This does not work at all for me.  Mapserver is   returning features in
  > gml2 format with this parameter, even if I am specially   asking for
  > gml3.1.1
  > Request WFS version 1.1.0 and without using   outputformat at all (WFS
  > 1.1.0 default is text/xml;   subtype=gml/3.1.1)
  > - > schema location contains
  > cgi-bin/wfstest?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=test&OUTPUTFORMAT=text/xml;
  >   subtype=gml/3.1.1
  > Running this query returns schema with reference to
  > "http://schemas.opengis.net/gml/3.1.1/base/gml.xsd"
  > Features in the GetFeature are in gml 3.1.1.   format.
  > I suppose this is working OK.  However, Mapserver   does not need
  > OUTPUTFORMAT parameter here but the result is the same even if I   leave
  > it out.
  > -Jukka Rahkonen-
  >     _____
  > Lähettäjä:   mapserver-users-bounces at lists.osgeo.org
  > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Roy   Braam
  > Lähetetty: 26. huhtikuuta 2010 14:26
  > Vastaanottaja:   mapserver-users at lists.osgeo.org
  > Aihe: [mapserver-users] invalid schema   location?
  > Hello List,
  > When i do a WFS getFeature request mapserver     returns a xml that starts
  > with:
  > <?xml version='1.0'     encoding="ISO-8859-1" ?>
  > <wfs:FeatureCollection
  >        xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
  >        xmlns:gml="http://www.opengis.net/gml"
  >        xmlns:wfs="http://www.opengis.net/wfs"
  >        xmlns:ogc="http://www.opengis.net/ogc"
  >        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
  >        xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
  > http://server.nl/geoservices/aankoopgebieden?SERVICE=WFS&amp;VERSION=1.1.0&amp;REQUEST=DescribeFeatureType&amp;TYPENAME=LL&amp;OUTPUTFORMAT=text/xml;
  >     subtype=gml/3.1.1  http://www.opengis.net/wfs
  > http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
  > numberOfFeatures="16">
  >           <gml:boundedBy>
  > If i read this     site:
  > http://www.w3.org/TR/xmlschema-0/#schemaLocation
  > the schema     locations needs to be "pairs of URI references, separated
  > by white     space".
  > Because the OUTPUTFORMAT="text/xml; subtype=gml/3.1.1" a space is     in
  > the url of the first pair in my example.
  > 1) spaces are not valid in     URLS??
  > 2) you don't have pairs anymore. You have a odd number of values if
  > you separate by space...
  > So, is mapserver generating a invalid XML?? Or     i'm doing something
  > wrong....
  > Version of mapserver =   5.6.3
  > Roy    _______________________________________________
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100504/d5e018d7/attachment-0001.html
