[mapserver-users] RE: How to avoid drawing overlapping point
symbols?
Sigda, Mark - Fort Collins, CO
Mark.Sigda at ftc.usda.gov
Tue May 4 14:51:16 EDT 2010
Thank you, Steve. I'm trying annotation, but haven't been able to get it working yet. I wasn't able to find examples of annotation layers, so I'm just hacking here. Would you please take a look at my map file?
Below is basically what I'm doing (though I have many more symbols & classes). If I use the map file below, it draws nothing. If I uncomment the commented lines, it draws both the marker symbols and labels, but I don't want labels.
Can you tell me how to draw just the marker symbols?
Thanks,
-Mark
SYMBOL
NAME "ROC"
TYPE TRUETYPE
FONT "nrcs-ssurgo"
CHARACTER ","
ANTIALIAS TRUE
END
LAYER
NAME "featpoint"
STATUS ON
TYPE ANNOTATION
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION "removed"
DATA "ShapeGeometry from featpoint using unique featpointiid using SRID=4269"
PROJECTION 'init=C:\ms4w\proj\nad\epsg:4269' END
CLASSITEM "featsym"
TRANSPARENCY ALPHA
# LABELITEM "featsym"
CLASS
EXPRESSION 'ROC'
STYLE
SYMBOL "ROC"
SIZE 12
COLOR 0 0 0
END
# LABEL
# ANTIALIAS true
# POSITION AUTO
# FONT "arial"
# TYPE truetype
# COLOR 0 0 0
# SIZE 8
# END
END
END
-----Original Message-----
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Monday, May 03, 2010 2:45 PM
To: Sigda, Mark - Fort Collins, CO; mapserver-users at lists.osgeo.org
Subject: RE: How to avoid drawing overlapping point symbols?
Use an annotation layer, you can even use the truetype symbol as the text, collisions will be avoided in this case. Even if you have to use the truetype symbol as a marker symbol with accompanying text MapServer will still avoid overlap with the markers.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sigda, Mark - Fort Collins, CO [Mark.Sigda at ftc.usda.gov]
Sent: Monday, May 03, 2010 2:52 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] How to avoid drawing overlapping point symbols?
I have a point layer I'm drawing with a truetype symbol. When points are close together, a big mess of overlapping symbols is drawn.
How can I tell MapServer not do draw symbols for points that are close together? I'm looking for something like GAP on the STYLE element, but that apparently applies only to line features.
Thanks,
-Mark
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
