[mapserver-users] mapserver logging
Chantal Rosmuller
chantal at antenna.nl
Mon May 10 08:11:27 EDT 2010
Thanks, guess I'll have to start experimenting :)
Op maandag 10 mei 2010 14:05:18 schreef Rahkonen Jukka:
> Hi,
> Look at the Mapserver documents it your users are sending Mapserver CGI
> calls and from Mapserver and OGC documents if they are doing WMS requests.
> It may be harder to deside what to search from the logs if you are running
> some program on the server that is sending the final requests to
> Mapserver. It is not trivial to analyse WMS calls either. Lines may be
> long and look odd, like this one including user style as SLD_BODY
> ip.ip.ip.1 - secured [05/May/2010:09:42:02 +0300] "GET
> /cgi-bin/securedwms?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=512&HEI
> GHT=642&LAYERS=testtest1&TRANSPARENT=TRUE&FORMAT=image%2Fpng&BBOX=316699.16
> 841900314,6691568.0,345950.9565809969,6728247.0&SRS=EPSG:3067&STYLES=&SLD_B
> ODY=%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22UTF-8%22%3F%3E%3CStyled
> LayerDescriptor%20version%3D%221.1.0%22%3E%3CNamedLayer%3E%3CName%3Etesttes
> t1%3C%2FName%3E%3CUserStyle%3E%3CFeatureTypeStyle%3E%3CRule%3E%3CName%3ERul
> e%201%3C%2FName%3E%3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3AP
> ropertyName%3test%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3test%3C%2Fogc
> %3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3CPolygo
> nSymbolizer%3E%3CStroke%3E%3CCssParameter%20name%3D%22stroke%22%3E%23000000
> %3C%2FCssParameter%3E%3CCssParameter%20name%3D%22stroke-width%22%3E5%3C%2FC
> ssParameter%3E%3C%2FStroke%3E%3CFill%3E%3CCssParameter%20name%3D%22fill%22%
> 3E%23FF0000%3C%2FCssParameter%3E%3CCssParameter%20name%3D%22fill-opacity%22
> %3E1%3C%2FCssParameter%3E%3C%2FFill%3E%3C%2FPolygonSymbolizer%3E%3C%2FRule%
> 3E%20%3C%2FFeatureTypeStyle%3E%3C%2FUserStyle%3E%3C%2FNamedLayer%3E%3C%2FSt
> yledLayerDescriptor%3E& HTTP/1.1" 200 4298
> However, you can start by calculating the number of GetMap calls. Next you
> can try to anylyze which layers are most popular but then you need to
> deside how handle requests like "&layers=layer_1,layer_2",
> "&layers=layer_2,layer_1" or "&layers=layer_3,layer_1,layer_2". It may
> also be hard to say from the logs if someone who asked for layer_1 ever
> got it. Request could have been outside the extents of the layer or then
> the request was not between the scale range.
> You can sum up the number of bytes you have sent. However, sometimes it
> could make more sense to count the number of pixels sent by multiplying
> WIDTH x HEIGHT because maybe compressed jpeg image is worth about as much
> for the end user as uncompressed 24 bit png. Or perhaps some statistics
> about BBOX suit your need better.
> I fear that for getting an answer to question "How many zoom actions" you
> must do some harder research. Mapserver or Apache do not know if someone
> is zooming or panning. I think I would take a sample and sort requests by
> the IP address and then try analyze by the timestamps how ofter users are
> making actions on a map. I suppose users could be classified to a few
> groups by their map activity. Then I would take a smaller sample from
> each group and repeat line by line all the requests and see what they
> really made on a map and try to understand why.
> -Jukka-
> Chantal Rosmuller wrote:
> > Thank you Jukka,
> > I am familiar with awstats but I would also like to analyse
> > information about
> > actual mapserver actions, like "ḧow many zoom actions". Your
> > tip is helpful
> > because indeed I see a lot of mapserver actions in the
> > requested url in the
> > apache log file. Can I find the meaning of all the get
> > variables somewhere in
> > the mapserver documentation?
> > Op maandag 10 mei 2010 12:16:25 schreef Rahkonen Jukka:
> > > Hi,
> > > There are two kind of logs. The one that Lars is referring
> > to is so called
> > > Mapserver errorfile and while it is good for debugging it
> > cannot be used
> > > for making statistics about visitors etc. Webserver
> > statistics can be
> > > made from the http server log files. For example in MS4W
> > installations
> > > http logs can be found from D:\Program
> > Files\ms4w\Apache\logs. What will
> > > be logged into these log files is configured in the Apache
> > httpd.conf
> > > file.
> > > Apache log files suit well for analysing WMS usage because
> > requests are
> > > coming through http GET method and then almost everything
> > gets stored into
> > > the log. If requests are coming though POST then Apache
> > access.log does
> > > not give as much information.
> > > There are many tools for analysing http server logs. Any
> > search engine will
> > > return you lots of reading if you have a try with "http
> > log analyze". I
> > > have been using AWStats and even the AWStats demo report
> > gives useful
> > > numbers about the number of visitors, bandwidth, top ten
> > IP addresses of
> > > the visitors etc. Perl programmer could make a report
> > that suits better
> > > for making statistics about Mapserver usage. I would start
> > by searching
> > > where the Apache access.log file is and having a look at
> > it with some text
> > > editor.
> > > -Jukka Rahkonen-
> > > > -----Alkuperäinen viesti-----
> > > > Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> > > > [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> > Lars Lingner
> > > > Lähetetty: 10. toukokuuta 2010 12:35
> > > > Vastaanottaja: mapserver-users at lists.osgeo.org
> > > > Aihe: Re: [mapserver-users] mapserver logging
> > > > On 10.05.2010 11:20, Chantal Rosmuller wrote:
> > > > > Hi list,
> > > > > I have a few questions about mapserver logging,
> > > > > Where can I change the log file location and logging verbosity?
> > > > > Where can I find documentation about the logfile syntax?
> > > > The debug parameter is described here:
> > > > http://mapserver.org/mapfile/map.html
> > > > > I would like to analyse the logfiles (get some statistiscs
> > > > about amount of
> > > > > visitors etc) is there software or a script for that or
> > > > should I write one
> > > > > myself?
> > > > I'm not aware of such an script.
> > > > Lars
> > > > _______________________________________________
> > > > mapserver-users mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
