[mapserver-users] Re: quick question from mapserver beginner!
mattmendick
matt.mendick at pictometry.com
Wed May 12 08:28:16 EDT 2010
You first have to make sure you are outputting the image as a png or some
other image format that supports transparency. Like this, at the base of the
mapfile:
OUTPUTFORMAT
NAME mypng
DRIVER "GD/PNG"
IMAGEMODE RGB
FORMATOPTION "INTERLACE=false"
MIMETYPE "image/png"
EXTENSION "png"
END
IMAGETYPE mypng
Then, if your source image is not perfectly square, and has black in areas
that you want to be transparent, you can use the "OFFSITE [R] [G] [B]"
attribute. This tells mapserver that any color in the raster that matches
the color in your OFFSITE parameter should be rendered transparent.
ex:
LAYER
NAME "blah"
DATA '/path/to/raster.tiff'
OFFSITE 0 0 0
END
This has worked for me in the past, I hope it works for you.
-Matt Mendick
View this message in context: http://osgeo-org.1803224.n2.nabble.com/quick-question-from-mapserver-beginner-tp5040040p5040856.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
