AW: [mapserver-users] layertype CHART - how to get the pie chart for
a specific polygon
Arnd Wippermann
arnd.wippermann at web.de
Mon May 17 17:47:13 EDT 2010
Hi
Thanks for the ideas
Without testing I would think straight Mapserver cgi will also not work,
because I use substitution with WMS and that works, and EXPRESSION is not
defined in the docs for layer CHART.
But I will try.
OWTChart I don't know, but I will have a look. Problem is, that I do not
know the data, but Mapserver knows them. It seems without some scripting,
In my application I use the pie chart for externalGraphic in OpenLayers. For
the WMS request I do not need to know the data for the chart.
I have hoped, that it were possible with MapServer alone to get the chart
for a specific polygon.
Regards,
Arnd
-----Ursprüngliche Nachricht-----
Von: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Gesendet: Montag, 17. Mai 2010 23:28
An: Arnd Wippermann; mapserver-users at lists.osgeo.org
Betreff: RE: [mapserver-users] layertype CHART - how to get the pie chart
Two ideas off the top of my head:
- use straight MapServer CGI and not WMS for the embedded chart request.
That way your idea for runtime subs might work.
- consider using something other than MapServer to build a stand-alone
chart. I'm guessing you have the data necessary to build the chart available
via the template and you could pass it to a charting tool. The old OWTChart
package is one example where you pass it the data via URL and it returns a
gif. I'm sure there are many other options...
Steve
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Arnd
Wippermann
Sent: Monday, May 17, 2010 2:06 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] layertype CHART - how to get the pie chart for a
specific polygon
i use the layertype CHART to display the results of the election in nrw 2010
for the electoral districts. It works great. The layer shows perfectly the
pie charts for every polygon.
http://gis.ibbeck.de/ginfo/apps/Landtagswahl_NRW_2010/Wahlen_NRW_2010.asp
But is it possible to get the pie chart for a specific polygon? I want to
display the pie chart i.e in a query like this:
http://gis.ibbeck.de/include/mapserv52/mapserv.exe?map=ginfo/apps/Landtagswa
hl_NRW_2010/Landtagswahl_NRW_2010.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetF
eatureInfo&QUERY_LAYERS=WKNR&LAYERS=WKNR&BBOX=965552.54116394,6743580.382492
7,980839.94681885,6758867.7881476&SRS=EPSG:900913&X=50&Y=50&WIDTH=100&HEIGHT
=100&FORMAT=image/png&INFO_FORMAT=text/html&FEATURE_COUNT=1&STYLES=
I have managed this in the template by use of <img src="WMS Request"> and
&BBOX=[shpext format="$minx,$miny,$maxx,$maxy"] in the WMS request for the
pie chart. And adjust of image width and pie chart size.
If the polygon has a polygon inside (isle), then this approach doesn't work,
because I get two pie charts:
hl_NRW_2010/Landtagswahl_NRW_2010.map&&SERVICE=WMS&VERSION=1.1.1&REQUEST=Get
FeatureInfo&QUERY_LAYERS=WKNR&LAYERS=WKNR&BBOX=951105.94282005,6738535.53862
66,966393.34847496,6753822.9442815&SRS=EPSG:900913&X=50&Y=50&WIDTH=100&HEIGH
T=100&FORMAT=image/png&INFO_FORMAT=text/html&FEATURE_COUNT=1&STYLES=
I would like to get the specific pie chart by the district number and cgi
substitution. That would mean, that one get a better control of displaying
the pies in an own context.
CLASS
EXPRESSION ([F12]=%WKNR%)
NAME 'CDU' #F10
STYLE
SIZE [F10]
COLOR 0 0 255 #000000
#OUTLINECOLOR 0 0 0
#WIDTH 1
END
END
But that doesn't work. Is there an other way possible?
Regards
Arnd Wippermann
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
