[mapserver-users] Re: OpenStreetMap + osm2pgsql = pgRouting
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue May 18 00:06:55 EDT 2010
The only experience I have on shortest paths is a little trial with an OpenJUMP plugin. However, with that plugin
I had to create first a planar graph. Perhaps you need to do something similar with your data first before system knows that it is allowed to continue from the endpoint of one linestring (A-B) to the startpoint of the next (B-C).
-Jukka Rahkonen-
roshni.spain wrote:
> Looking further into the matter,
> i have noticed that the only cases where i have managed to get some result
> with the shortest_path function is when there is a straight line between A
> and B, but if i need to do A and C, and there is no straight line between
> them (suppose something like A => B => C), then no result will be returned
> The same applies for other routing algorithms ... and still no clue
