[mapserver-users] Testing KML support
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu May 20 11:28:01 EDT 2010
Hi Peter,
  I have updated the RFC after some cleanup in the code
(http://svn.osgeo.org/mapserver/branches/branch-5-6/docs/en/development/rfc/ms-rfc-58.txt).
  Note also that there is a componenent Output-KML in MapServer trac
(http://trac.osgeo.org/mapserver/), for reporting issues.
best regards,
On 07/05/2010 5:02 PM, Yewondwossen Assefa wrote:
> Hi Peter,
> There is supposed to be --with-kml.
> I have added the OUTPUT=KML if built with the flag.
> Note that the driver is still in development/cleanup state. I will
> update the RFC  (http://mapserver.org/development/rfc/ms-rfc-58.html)
> once this phase is over.
> regards,
> On 07/05/2010 12:23 PM, Peter Hopfgartner wrote:
>> Hi,
>> I'm would like to look at the KML functionality in the current MapServer
>> trunk.
>> There does not seem to be any specific option in configure, so I enabled
>> it by setting the environment variable CPPFLAGS:
>> $ export CPPFLAGS=-DUSE_KML
>> $ ./configure --with-proj --with-postgis --with-cairovim
>> --with-xml2-config=/usr/bin/xml2-config
>> $ make
>> The resulting shp2img has a lot of Kml-related symbols in it:
>> $ nm shp2img | grep -i kml | wc -l
>> 71
>> Anyway, KML does not seem to be oin the OUTPUT formats list:
>> [peter.hopfgartner at vm-centos5-64-1 mapserver]$ ./shp2img -v
>> MapServer version 5.7-dev OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=WMS_SERVER INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
>> Indeed, trying to produce some KML from a map file, I get:
>> $ /usr/local/bin/shp2img -i KML -m kml_test.map>  test.kml
>> loadOutputFormat(): General error message. OUTPUTFORMAT clause
>> references driver KML, but this driver isn't configured.<br>
>> Am I missing something?
>> Regards,
>> Peter
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
