[mapserver-users] Map background color using OL/WMS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue May 25 08:23:27 EDT 2010
Paul james wrote:
> Hello all...
> I have a Mapserver WMS application (using OL) ...
> How can I set the map background color?
> I tried to use :
> MAP
> IMAGECOLOR 230 254 254
> Without success...
> Tried too :
> METADATA
> "wms_bgcolor" "0x8B0000"
> No color change...
To test your MapServer mapfile I recommend using the shp2img commandline
utility (http://www.mapserver.org/utilities/shp2img.html). Once you
have shp2img's resulting map image looking like you want, then you can
test in your application. (this is how I would debug your problem, if I
was hitting your issue)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
