[mapserver-users] Filter duplicate elements
SF sf at pegase-systems.com
Wed Nov 3 11:36:50 EDT 2010
I try to render simplified S57 files using MapServer with flash output. But
there are maps at various scales for the same area, which overlap. It is not
a problem for land or sea area, but I want to filter features to avoid
duplicates entries. In the S57 files, there is a worldwide identifier for
each feature. I wonder if it would be possible to use this ID to filter
duplicates, or if you must use mapscript or home made algorithm to do this.
Thank you in advance.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Filter-duplicate-elements-tp5701822p5701822.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
