AW: [mapserver-users] Filter elements on multiple layers
leene leene_85 at yahoo.de
Thu Nov 4 03:48:26 EDT 2010
thank you Alex. I found the solution in the same thread, you've posted:
http://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg10704.html
I must add the <BBOX> of the whole map to the filter and I'll get all matches.
Regards,
Cathleen
Von: Alexander Petkov <greenkov at gmail.com>
An: leene <leene_85 at yahoo.de>
CC: mapserver-users at lists.osgeo.org
Gesendet: Mittwoch, den 3. November 2010, 20:30:39 Uhr
Betreff: Re: [mapserver-users] Filter elements on multiple layers
Hmm, I just tested this--it seems that you'd always get features where
the envelopes for the results from each layer spatially intersect,
(i.e. anything within the blue rectangle of your image).
Alex
On Wed, Nov 3, 2010 at 11:37 AM, Alexander Petkov <greenkov at gmail.com> wrote:
> You might have to specify your filter for each typename, as in:
>http://my-server/fcgi-bin/mapserv&map=mymap.map&service=WFS&version=1.1.0&request=GetFeature&typename=layer1,layer2&FILTER=(<Filter>...</Filter>)(<Filter>...</Filter>)
> See this thread:
> http://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg10695.html
> Alex
> On Wed, Nov 3, 2010 at 8:44 AM, leene <leene_85 at yahoo.de> wrote:
>> Hey,
>> I have a problem with filtering elements of multiple layers.
>> My mapserver (version 5.2.1) is configured with two layers - layer1 and
>> layer2. For better understanding see attachment: layer1 has black crosses
>> and layer2 has red points. Now I try to get features by id - but I don't
>> know the corresponding layer. Therefore I send the following request:
>>http://my-server/fcgi-bin/mapserv?map=mymap.map&service=WFS&version=1.1.0&request=GetFeature&typename=layer1,layer2&filter=
>> <Filter><OR>
>><PropertyIsEqualTo><PropertyName>ID</PropertyName><Literal>idAofLayer1</Literal></PropertyIsEqualTo>
>><PropertyIsEqualTo><PropertyName>ID</PropertyName><Literal>idBofLayer1</Literal></PropertyIsEqualTo>
>><PropertyIsEqualTo><PropertyName>ID</PropertyName><Literal>idCofLayer2</Literal></PropertyIsEqualTo>
>> </OR></Filter>
>> In the response are some features missing but they exist in the shapefile. I
>> found out following rules:
>> 1. All features of layer2 (red points in attachment) are returned correctly.
>> 2. Features of layer1 (black crosses) which are inside the blue frame are
>> also returned correctly.
>> 3. Features of layer1 which are outside the blue frame (bounds of layer2)
>> are missing - if I filter the missing elements only on layer1 I get the
>> features.
>> Is this a bug or where is my mistake?
>> Regards,
>> Cathleen
>> By the way: Is there a date of mapserver 6 release?
>> http://trac.osgeo.org/mapserver/wiki/60ReleasePlan doesn't seem to be up to
>> date.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101104/2bc2fe5f/attachment-0001.html
