[mapserver-users] map file paths
John Callahan john.callahan at udel.edu
Thu Nov 4 10:18:01 EDT 2010
The PHP mapscript wrapper looks promising.  Thanks. The examples would need
to be combined into one php file to handle both GetMap and GetCapabilities
requests. Seems doable.  I'm not a programmer and didn't want to get into
mapscript, however, modifying this script template doesn't seem too
difficult (if you already have PHP, which my server does.)
I'm not a big fan of copying and renaming the mapserv.exe file but it does
work well. We only publish a handful of services and do not expect to
significantly increase in the future.  If we do, scripting a batch file
would work just as well.  This is relatively easy and without the need to
install (re: maintenance, security) or learn additional programming
languages.
For me, it's also important to have short, easily readable URLs to send out
to people that use our WMS services.  I do not want the extra "?map=mymap"
parameters at the end of the URLs.  For one reason or another, things always
get screwed up when people start pasting these URLs into their desktop GIS
or other apps.  Simpler the better, even if it's not elegant or involves
slightly more work on my part.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Thu, Nov 4, 2010 at 2:53 AM, Waberzeck, Thomas <
Thomas.Waberzeck at liag-hannover.de> wrote:
> Jukka Rahkonen wrote:
> > P Kishor wrote:
> > > So you have 15 copies of the binary floating around on your computer.
> > > What a nightmare. If you upgrade, you have to make 15 copies of the
> > > new version and replace the old version.
> > > What would happen when you publish the 150th geologic map?
> > > Use a single binary, and use a wrapper (or the env variable) to get
> > > the right query.
> > I do not believe there are handy wrappers for Windows and the only way
> > I have been able to get SetEnvIf to work is to make copies of
> > mapserv.exe with different names. I maintain a batch file about our
> > services with lines like "COPY mapserv.exe WMS_service1" etc. and then
> > I only need to run the batch after update and publishing the 150th
> > service does not change anything.
> If you have php it's quite easy to write a small wrapper for it. See
> http://www.mapserver.org/ogc/mapscript.html#php-example so the only thing
> to do is to write the wrappers once and you have a single setup of
> Mapserver.
> Thomas
> BTW: The Example should be updated - I think php_mapscript_4.10.0.dll is
> out of date. The name of the .dll is just php_mapscript.dll.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101104/496495ef/attachment.html
