[mapserver-users] testing WMS GetMap
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Nov 9 00:17:19 EST 2010
Mapserver documentation lists the compulsory parameters in section Test With a GetMap Request
http://mapserver.org/ogc/wms_server.html
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: David Hildebrand
Lähetetty: ti 9.11.2010 0:41
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] testing WMS GetMap
I am trying to test my MapServer WMS configuration.  I can successfully
test the GetCapabilities.  However, when I test GetMap I get the typical
"HTTP 404: URL not found" error.  The native mapserv CGI is functioning
because I can serve maps.  However, I may need a couple of pointers on
WMS URL syntax.  Do I need an SRS parameter if this is set in the map
file?  Do I need the BBOX parameter if I want the full extent as defined
in the map file?  What about WIDTH, HEIGHT and FORMAT?
Thanks.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca>  <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
