[mapserver-users] draw polygons ordered by field ? (from File System)
Sebastian E. Ovide sebastian.ovide at gmail.com
Tue Nov 9 08:25:30 EST 2010
Hi All,
Reading a shapefile (ESRI/MapInfo) from FS with polygons overlapping. Each
polygon is drawn with a different color based on a field called RISK.
Is it possible  define an order on how the polygons are drawn ? Say for
example to draw the polygons with field "RISK" 0 first, then with "RISK" =1
and so on...
I know that using PG we can use "Select * from XXX order by RISK"
Is there any way to do that using ESRI/MapInfo files ?
Thanks
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101109/b177ba50/attachment.html
