[mapserver-users] Mapserver SQL Server 2008 R2 connection
Milena mgebreab at maxgeo.com
Wed Nov 10 03:00:58 EST 2010
Hi All,
I really appricate any help on this.
I am trying to create a WMS using mapserver and data from SQL 2008 R2. This
is what my map file looks like.
SIZE 600 800
  PROJECTION
   "init=epsg:4326" #latlon on WGS84
  END
  EXTENT 113 -34 129 -14
  # lon/lat extents of Spatial
  WEB
    IMAGEPATH "/tmp/ms_tmp/"
    IMAGEURL "/ms_tmp/"
    METADATA
      "map" "C:/OSGeo4W/apps/Spatial/config.map"
      "ows_schemas_location" "http://schemas.opengeospatial.net"
      "ows_title" "Sample WMS"
      "ows_abstract" "Sample WMS of Spatial"
      "ows_keywordlist" "Spatial,WMS,Maxwell"
      "ows_onlineresource"
"http://localhost:8080//Spatial?map=C:/OSGeo4W/apps/Spatial/config.map&"
      "wms_srs" "EPSG:4326" #latlon
      "wms_feature_info_mime_type" "text/plain"
      "wms_feature_info_mime_type" "text/html"
      "wms_server_version" "1.1.1"
      "wms_formatlist" "image/png,image/gif,image/jpeg"
      "wms_format" "image/gif"
    END #metadata
  END #web
  LAYER
  NAME "tenements"
  CONNECTIONTYPE PLUGIN
  PLUGIN "C:/OSGeo4W/specialplugins/msplugin_mssql2008.dll"
  CONNECTION "Provider=SQLOLEDB.1;Integrated Security=SSPI;Persist Security
Info=False;Initial
Catalog=SpatialDB;Data Source=AU-FRE-L0217//SQL_2008R2"
  DATA "SP_GEOMETRY from dbo.tenements"
  TYPE POLYGON
  STATUS ON
  METADATA
      "ows_title" "tenements"
    END #metadata
    PROJECTION
      "init=epsg:4326"
    END
  END #Layer
End #Map
I am using msplugin_mssql2008.dll plugin. But I keep getting 500 internal
error:
I checked the even view and the error there says:
Faulting application name: mapserv.exe, version: 0.0.0.0, time stamp:
0x4ab3c473
Faulting module name: libmap.dll, version: 0.0.0.0, time stamp: 0x4ab3c46e
Exception code: 0xc0000005
Fault offset: 0x000a7815
Faulting process id: 0x178c
Faulting application start time: 0x01cb80a63078252e
Faulting application path: C:\OSGeo4W\bin\mapserv.exe
Faulting module path: C:\OSGeo4W\bin\libmap.dll
Report Id: 6f925ed2-ec99-11df-a20d-b8ac6f7484b2
Appache error log error message is:
[Wed Nov 10 13:56:35 2010] [error] [client 127.0.0.1] Premature end of
script headers: mapserv.exe
[Wed Nov 10 13:59:04 2010] [error] [client 127.0.0.1] Premature end of
[Wed Nov 10 15:09:21 2010] [error] [client 127.0.0.1] Premature end of
Please help!!
Thank you
Milen
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mapserver-SQL-Server-2008-R2-connection-tp5723789p5723789.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
