[mapserver-users] WMS identify within ArcGIS
David Hildebrand David.Hildebrand at afsc.ca
Wed Nov 10 19:02:27 EST 2010
It seems that ArcMap only supports text/plain output for WMS info_format
even when requested otherwise.  To my knowledge this format does not
return attribute values but simply feature numbers (someone correct me
if I am wrong).  I have a support call into ESRI even as we speak so I
will pass that information along when I get it.
Till later,
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca>  <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
  _____
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Wednesday, November 10, 2010 2:58 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] WMS identify within ArcGIS
Hello,
I am trying to set up Mapserver as a WMS server.  Currently I can draw
maps.  However, I am having trouble getting the server to support
Identify, specifically within ArcGIS.
Does anyone have an example map file and template that allows WMS
Identify in ArcGIS.
Thank You
Mark Volz
GIS Specialist
Lyon County, MN
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101110/90f71332/attachment.html
