[mapserver-users] WMS identify within ArcGIS
David Hildebrand David.Hildebrand at afsc.ca
Fri Nov 12 18:45:11 EST 2010
Mark:
I did a bit of digging and discovered a couple of things with respect to
GML encoding.  The ESRI documentation states that GML is supported and,
in fact, encouraged with WFS services
(http://webhelp.esri.com/arcgisserver/9.3/dotNet/index.htm#wfs_service.h
tm).  However, because WMS services are not designed to deliver
geographic data but simply map images GML is not supported from WMS
services.  ArcGIS desktop does, indeed, support GML from WFS services
and the Data Interoperability extension extends that support to a number
of different schemas
(http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=An_overvi
ew_of_GML_support_in_ArcGIS).  I'm not sure, however, if the Data
Interoperability extension would be required.  I suspect not but I may
be wrong.  In short, if you want to use GML for attribute encoding in
ArcMap, set up your service as WFS and try it.  Otherwise, text/html
might just have to suffice.
Hope this helps.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca>  <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
  _____
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of David
Hildebrand
Sent: Friday, November 12, 2010 12:02 PM
To: Mark Volz
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] WMS identify within ArcGIS
Mark:
Apparently I was in error.  I restarted apache this morning and when I
loaded the layer in question into ArcMap and did an "Identify" I got the
results I wanted.  I am not an apache guru so I'm not exactly sure what
I did right.
In the WEB>METADATA section of my map file I have the line
"wms_feature_info_mime_type" "text/html".  For each layer have the lines
  TEMPLATE "layer.html"
  DUMP TRUE
The html template as well as the relevant map files are attached.
This configuration works for text/html output but I'm not sure if ESRI
supports GML.  Hope this helps.
David V. Hildebrand
(403) 782-8239
email.
  _____
Hildebrand
Sent: Wednesday, November 10, 2010 5:02 PM
To: mapserver-users at lists.osgeo.org
Cc: Mark Volz
It seems that ArcMap only supports text/plain output for WMS info_format
even when requested otherwise.  To my knowledge this format does not
return attribute values but simply feature numbers (someone correct me
if I am wrong).  I have a support call into ESRI even as we speak so I
will pass that information along when I get it.
Till later,
David V. Hildebrand
(403) 782-8239
email.
  _____
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Wednesday, November 10, 2010 2:58 PM
Subject: [mapserver-users] WMS identify within ArcGIS
Hello,
I am trying to set up Mapserver as a WMS server.  Currently I can draw
maps.  However, I am having trouble getting the server to support
Identify, specifically within ArcGIS.
Does anyone have an example map file and template that allows WMS
Identify in ArcGIS.
Thank You
Mark Volz
GIS Specialist
Lyon County, MN
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101112/a64c5d2e/attachment-0001.html
