[mapserver-users] msProcessProjection(): Projection library error. no system list, errno: 2
Michael Schulz mschulz at webgis.de
Thu Nov 18 12:31:05 EST 2010
the projection-lib cannot find the epsg file, where all the
projections are defined. Add
CONFIG "PROJ_LIB" "/usr/local/share/proj/nad"
your mapfile (you may have to adjust the path).
Cheers, Michael
2010/11/18 Sebastian E. Ovide <sebastian.ovide at gmail.com>:
> Hi All,
> I'm using an map file that works fine on one server, but for some reason on
> another server (just installed: Fedora) it is giving this error:
> [Thu Nov 18 17:23:03 2010].578122 msProcessProjection(): Projection library
> I've already set DEBUG 5 and CONFIG "CPL_DEBUG" "ON" bat I cannot find any
> extra information that could help to understand what the problem is.. (I've
> built mapserver with debug flag)
> any ideas ?
> Sebastian E. Ovide
> mapserver-users at lists.osgeo.org
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100  Freiburg i. Br.
Tel:  +49 (0)761 705798-102
Tel:  +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
