[mapserver-users] Label backgroundcolor
thomas bonfort thomas.bonfort at gmail.com
Fri Nov 19 10:01:27 EST 2010
BUFFER used to also expand the size of the billboard, but that's not
the case anymore. I don't think it's currently possible to expand the
billboard, although it should soon be possible to do so in the near
future (we can also imagine rounded rectangle billboards to).
(the following is slightly off-topic, bu at least it will be written
down somewhere to integrate in the migration guide)
we'll probably be removing backgroundcolor and backgroundshadowcolor,
and replace them with something like
LABEL
   xxx
   STYLE
      GEOMTRANSFORM LABELPOLY    #this is were other keywords would be
used for expanding the billboard
      COLOR xxx #ex bgcolor
      OUTLINECOLOR xxx
      OFFSET 1 1 #use an offset for obtaining the same result as
      SYMBOL 'hatch' #let your imagination play
   END
END
regards,
thomas
On Fri, Nov 19, 2010 at 15:52, Fawcett, David (MPCA)
<David.Fawcett at state.mn.us> wrote:
> Thanks Michael.
> BUFFER just does what I expected it to do.  The labels are farther apart and one of them doesn't get drawn because there isn't room for it.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Michael Schulz
> Sent: Friday, November 19, 2010 4:35 AM
> To: Fawcett, David (MPCA)
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Label backgroundcolor
> Hi David,
> not sure, but have you tried using/increasing the BUFFER value of the label?
> Cheers, Michael
> 2010/11/18 Fawcett, David (MPCA) <David.Fawcett at state.mn.us>:
>> I know that you can set a shadow for the backgroundcolor (billboard).
>> Can you increase the size of the billboard? E.g. 5 pixels all of the way around?
>> Thanks,
>> David.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Michael Schulz
> mschulz at webgis.de
> in medias res
> Gesellschaft für Informationstechnologie mbH
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
