[mapserver-users] MapServer output
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Fri Nov 19 15:41:07 EST 2010
Here's a public facing app with KML output via template:
  http://www.dnr.state.mn.us/watertrails/interactive_map/index.html?mapext=461232.421875%205056798.828125%20509056.640625%205085802.734375
If you click on a water trail line you'll see a KML option. It does a query and generates multiple layer/feature KML file via a template... The output is compressed across the wire (thanks to mod-deflate) but appears uncompressed to the user when the file arrives.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of P Kishor
Sent: Friday, November 19, 2010 2:31 PM
To: Fawcett, David (MPCA)
Cc: Mapserver-users
Subject: Re: [mapserver-users] MapServer output
On Fri, Nov 19, 2010 at 1:01 PM, Fawcett, David (MPCA)
<David.Fawcett at state.mn.us> wrote:
> Puneet,
> Attached is a template file that I use to generate KML files.  This one was used to create KML points for some oblique air photos that someone in our agency shot.
This is great! Thanks. Is there a public facing URL where I can test
your implementation of the above? Which version of MapServer are you
using to do this?
> The format was gratuitously stolen from an example that Steve Lime gave me...
> David.
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lime, Steve D (DNR)
> Sent: Friday, November 19, 2010 12:32 PM
> To: Frank Warmerdam; P Kishor
> Cc: Mapserver-users
> Subject: RE: [mapserver-users] MapServer output
> I believe Frank's work extends beyond WFS as well to standard MapServer queries, or if that's not possible yet it can be.
> Remember also that you have query templates at your disposal which can be used to generate any number of text-based formats.
> Steve
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
