[mapserver-users] LABEL POSITION - Numeric or String from adatabase
Donald Kerr donald.kerr at dkerr.co.uk
Sun Nov 21 10:20:15 EST 2010
This works (see code below) but would require 30 x 9 classes where,
previously there were 30.
LABELITEM removed
TEXT added
EXPRESSION changed - added anchorpositiontxt - I would need 9 x classes for
each feature code (30).
I am guessing that there must be a way to achieve this without having to
move from 30 to 270 classes.
#LABELITEM textstring
CLASS
	# Building
	EXPRESSION (([featurecode] = 10020) And
("[anchorpositiontxt]"="cc"))
	TEXT ([textstring])
	LABEL
		TYPE truetype
		FONT arial
		SIZE [height]
		POSITION cc
		COLOR [oscolor]
		ANTIALIAS TRUE
		ANGLE [orientation]
		FORCE TRUE
	END # LABEL
END # CLASS
Regards,
Donald
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Donald Kerr
Sent: 21 November 2010 14:34
To: 'tommaso'
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] LABEL POSITION - Numeric or String from
adatabase
Tommaso,
There are already 30 classes, each with their own attributes, some of which
also come from the database (see example below). I don't think I can also
use CLASSITEM and two EXPRESSIONs.
CLASS
	# Building
	EXPRESSION ([featurecode] = 10020)
	LABEL
		TYPE truetype
		FONT arial
		SIZE [height]
		POSITION cc
		#POSITION [AnchorPositionTxt]
		COLOR [oscolor]
		ANTIALIAS TRUE
		ANGLE [orientation]
		FORCE TRUE
	END # LABEL
END # CLASS =======================================================
Regards,
Donald
Sent: 21 November 2010 13:59
To: Donald Kerr
Subject: Re: [mapserver-users] LABEL POSITION - Numeric or String from a
database
Hallo Donald,
you can define a layer with so many classes how are your possible label
positions and filter each class with the value of the attribute
"AnchorPositionTxt"
i.e:
LAYER
  NAME "layer"
  CLASSITEM "AnchorPositionTxt"
  LABELITEM "name"
  CLASS
    EXPRESSION "ul"
    LABEL
        POSITION ul
    END
  END
  CLASS
    EXPRESSION "lr"
    LABEL
        POSITION lr
    END
  END
END
Cheers,
Tommaso
On Sun, 2010-11-21 at 10:21 +0000, Donald Kerr wrote:
Hi List,
I am trying to change a LABEL's POSITION by using an integer without
success.
As far as I can see, the LABEL's POSITION can be any one of the following
constants: enum MS_POSITIONS_ENUM {MS_UL=101, MS_LR, MS_UR, MS_LL, MS_CR,
MS_CL, MS_UC, MS_LC, MS_CC, MS_AUTO, MS_XY , MS_FOLLOW};
I was assuming that I can replace UL with "101" i.e. instead of "POSITION
UL" I use "POSITION 101" but that doesn't work.
I have also tried replacing "POSITION UL" with text values from a database
i.e. "POSITION [AnchorPositionTxt]" where "AnchorPositionTxt" is a string
'UL' but, again, that doesn't work.
Is there a way to set this value dynamically from the database with either
numbers or strings ('UL', LR, etc...)?
Many thanks.
Regards,
Donald Kerr
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
