[mapserver-users] Re: EPSG:4326 with WMS 1.3.0
Vincent Heurteaux vincent.heurteaux at geomatys.com
Sun Nov 21 13:11:18 EST 2010
Hello Jukka,
Thank's for your feedback. After a closer look to WMS 1.3.0 specification (OGC 06-042, section 6.7.2 page 15), it appears that you are totally right.
Thank's again,
Vincent
Le 21 nov. 2010 à 16:38, Rahkonen Jukka a écrit :
> vheurteaux wrote:
>> Hello Jukka,
>> You said "You may see rotated maps if you open gml vector data returned by
> WFS 1.1.0 service with a client than can't handle axis flipping but that is
> a client error".
>> Do we agree that the server is expected to return a rotated map, and that
> the client is expected to put it back in the right orientation?
> Not really, I fear. Even WFS server does not send rotated maps, it is sending normally oriented vector maps with coordinates in order northing-easting with some projections. The vector map client is expected to parse the coordinates correctly by following the projection definitions.  For example UTM zones are always easting-northing and WFS output from versions 1.0.0 and 1.1.0 have the same axis order.
>> Do we agree that on a client with no such capability (for example when
> viewing the image directly in the internet browser), the image in EPSG:4326
> shall appear rotated?
> WMS is sending images as they should appear on the screen and client is not supposed to do any pixel-by-pixel warping. Only thing that a proper WMS 1.3.0 client need to do is to build BBOX with correct axis order, either easting-northing or northing-easting.  A not-proper WMS 1.3.0 client will build BBOX with wrong axis order (again, with some projections) and get back a north-up image from some other place of the world, not a rotated image.
> -Jukka Rahkonen-
> Cheers
> Vincent
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/EPSG-4326-with-WMS-1-3-0-tp5756000p5757819.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
