[mapserver-users] Spatial Filter with WFS
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Nov 23 09:00:34 EST 2010
Andreas, you may be without a wsf:Query element.  Here is a WFS 1.0.0 request that works with Geoserver.
<?xml version="1.0" encoding="ISO-8859-1"?>
<wfs:GetFeature xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.0.0" maxFeatures="1000" outputFormat="GML2">
<wfs:Query xmlns:topp="http://www.openplans.org/topp" typeName="topp:states">
<ogc:Filter>
<ogc:Intersects xmlns:gml='http://www.opengis.net/gml' >
<ogc:PropertyName xmlns:topp="http://www.openplans.org/topp">
topp:the_geom</ogc:PropertyName>
<gml:Polygon srsName="EPSG:4326">
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates cs="," decimal="." ts=" ">
409350.0,5709890.0 409350.0,5709910.0 409370.0,5709910.0 409370.0,5709890.0 409350.0,5709890.0</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ogc:Intersects>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Y.A, a question for you:  I have thought that also the filters should be presented as gml3 with WFS 1.1.0 and thus posList should be used instead of coordinates. Am I wrong with this belief?  By the way, this is how Geoserver 2.1 beta 1 writes out on multipolygon as gml3
<topp:the_geom>
<gml:MultiSurface srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:surfaceMember>
<gml:Polygon>
<gml:exterior>
<gml:LinearRing>
<gml:posList>
37.51099000000001 -88.071564 37.476273000000006 -88.087883 37.442852 -88.311707 37.40930899999999 -88.359177
-Jukka Rahkonen-
	Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Yewondwossen Assefa
	Lähetetty: 23. marraskuuta 2010 15:43
	Vastaanottaja: Rahkonen Jukka; Fischer, Andreas
	Kopio: mapserver-users at lists.osgeo.org
	Aihe: Re: [mapserver-users] Spatial Filter with WFS
	Hi all,
	As noted MapServer does not support gml:Surface. The original request with gml:Polygon seems to be correct.
	Andreas, is it possible to package it and send it to me off list. I can quickly check what the issue is.
	regards,
	 as noted Mapserver does not support gml:Surface.
	On 23/11/2010 8:26 AM, Rahkonen Jukka wrote:
		This one may not be the only problem, but I would start by creating a valid WFS 1.1.0 request by giving a filter as gml3 or alternatively go on with using gml2 filter but changing version to WFS 1.0.0.  Here below is a WFS 1.1.0 request that works against deegree.  It does not necessarily work against Mapserver because it can well be that Mapserver does not support gml:Surface, even if the surface is a plain polygon as in this  case.  However, you see that gml3 does not use <gml:coordinates, it is using <gml:posList and it would be a miracle or Mapserver bug or both if your request works.
		<wfs:GetFeature xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.1.0" maxFeatures="1000" outputFormat="text/xml; subtype=gml/3.1.1">
		<wfs:Query xmlns:app="http://www.deegree.org/app" srsName="EPSG:26912" typeName="app:Counties">
		<ogc:Filter>
		<ogc:PropertyName xmlns:app="http://www.deegree.org/app">
		app:position</ogc:PropertyName>
		<gml:Surface srsName='EPSG:26912' >
		<gml:patches>
		<gml:PolygonPatch>
		<gml:exterior>
		<gml:LinearRing>
		<gml:posList srsDimension='2' count='6'>
		87.0 198.0 149.0 239.0 261.0 202.0 263.0 89.0 161.0 80.0 87.0 198.0</gml:posList>
		</gml:LinearRing>
		</gml:exterior>
		</gml:PolygonPatch>
		</gml:patches>
		</gml:Surface>
		</ogc:Intersects>
		</ogc:Filter>
		</wfs:Query>
		</wfs:GetFeature>
		-Jukka Rahkonen-
		Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Fischer, Andreas
		Lähetetty: 22. marraskuuta 2010 19:36
		Vastaanottaja: mapserver-users at lists.osgeo.org
		Aihe: [mapserver-users] Spatial Filter with WFS
		Dear MapServer-User,
		I configured MapServer version 5.6.5 as WMS- and WFS-Server to offer information about land and properties. I use PostgreSQL/PostGIS (8.4.4/1.5.1) as datastore in this case. The spatial reference system is EPSG:25832 und the type of the geometry is MULTIPOLYGON. OS is Suse Linux Enterprise Server 11, Servicepack1.
		WMS and WFS work fine until I use a spatial filter within the getFeature-Request of the WFS. In this case the response doesn't deliver any features. Nevertheless the number of features (e.g. numberOf Features='4') is correct. I tried this out with a couple of different boundingboxes and the known number of features that intersect these boundigboxes. In all cases I do not get any features back, but always the right number. So it seems that at least the intersection of the boundingbox and my data works correctly.
		Please take a look at the following request and response that illustrate that problem:
		Request:
		http://myserver/cgi-bin/mapserv?map=/mapserver/mapfiles/u218768/ku_testwfs.map&REQUEST=getFeature&typename=folie001&SERVICE=WFS&VERSION=1.1.0&
		Filter=<ogc:Filter>
		                <Intersects>
		                        <ogc:PropertyName>msGeometry</ogc:PropertyName>
		                        <gml:Polygon srsName='EPSG:25832'>
		                                        <gml:LinearRing>
		                                                <gml:coordinates>409350,5709890 409350,5709910 409370,5709910 409370,5709890 409350,5709890</gml:coordinates>
		                                        </gml:LinearRing>
		                        </gml:Polygon>
		                </Intersects>
		        </ogc:Filter>
		Response
		<?xml version="1.0" encoding="ISO-8859-1" ?>
		<wfs:FeatureCollection xmlns:ms="http://mapserver.gis.umn.edu/mapserver" xmlns:gml="http://www.opengis.net/gml" xmlns:wfs=http://www.opengis.net/wfs xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver http://myserver/cgi-bin/mapserv?map=/mapserver/mapfiles/u218768/ku_testwfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=folie001&OUTPUTFORMAT=text/xml; subtype=gml/3.1.1 http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" numberOfFeatures="4">
		<gml:boundedBy>
		<gml:Envelope srsName="EPSG:25832">
		                        <gml:lowerCorner>-1.000000 -1.000000</gml:lowerCorner>
		                                <gml:upperCorner>-1.000000 -1.000000</gml:upperCorner>
		                </gml:Envelope>
		        </gml:boundedBy>
		</wfs:FeatureCollection>
		Indeed of this behavior the WFS returns features when I do not use a spatial filter. Therefore in my opinion the WFS should be configured right in general. To me the spatial filter seems to be the problem. Unfortunately I do not have any ideas what is going wrong.
		For more information you can take a look at my MapFile and a part of the capabilities document returned from the WFS below:
		MAP
		        NAME "ku_testwfs"
		        STATUS ON
		        SIZE 400 520
		        EXTENT 389965 5693582 420177 5732815
		        UNITS METERS
		        PROJECTION
		                "init=epsg:25832"
		        END
		        SYMBOLSET "/mapserver/symbols/symbols_alk.sym"
		        FONTSET "/mapserver/fonts/fonts.fnt"
		        IMAGECOLOR 255 255 255
		        WEB
		                IMAGEPATH "/mapbender/mb262/http/tmp/"
		                IMAGEURL "http://myserver/mapbender/tmp/"
		                METADATA
		                        "ows_onlineresource" "http://myserver/cgi-bin/mapserv?map=/mapserver/mapfiles/u218768/ku_testwfs.map"
		                        "ows_title" "Liegenschaftskarte, Kreis Unna"
		                        "ows_accessconstraints" "Nutzung nur für den Dienstgebrauch."
		                        "ows_abstract" "Flurstücksfolie der Liegenschaftskarte."
		                        "ows_contactperson" "Andreas Fischer"
		                        "ows_contactorganization" "Kreis Unna"
		                        "ows_contactposition" "Zentrale Datenverarbeitung, Geodatenmanagement"
		                        "wms_srs" "EPSG:25832 EPSG:31462 EPSG:31463 EPSG:31466 EPSG:31467 EPSG:4326"
		                        "wms_feature_info_mime_type" "text/html"
		                        "wfs_srs" "EPSG:25832"
		                END #METADATA
		        END #WEB
		        LAYER
		                NAME "folie001"
		                STATUS ON
		                TYPE POLYGON
		                DUMP TRUE
		                CONNECTIONTYPE postgis
		                CONNECTION "user=dbuser password=dbpassword dbname=dbname host=dbhost port=dbport"
		                DATA "the_geom from ku_view_folie001 USING UNIQUE objnr USING SRID=25832"
		                METADATA
		                        "ows_title" "Flurstücke"
		                        "wfs_extent" "389965 5693582 420177 5732815"
		                        "gml_include_items" "all"
		                        "gml_featureid" "objnr"
		                END #METADATA
		                CLASS
		                        NAME "Flurstücke"
		                        STYLE
		                                OUTLINECOLOR 0 0 0
		                                WIDTH 1
		                        END # STYLE
		                END  # CLASS
		        END #LAYER
		END #MAPFILE
		- <     FeatureTypeList>
		- <     Operations>
		  <Query />
		  </Operations>
		- <FeatureType>
		  <Name>folie001</Name>
		  <Title>Flurstücke</Title>
		  <SRS>EPSG:25832</SRS>
		  <LatLongBoundingBox minx="389965" miny="5.69358e+06" maxx="420177" maxy="5.73282e+06" />
		 </FeatureType>
		 </FeatureTypeList>
		- <ogc:Filter_Capabilities>
		- <ogc:Spatial_Capabilities>
		- <ogc:Spatial_Operators>
		  <ogc:Equals />
		  <ogc:Disjoint />
		  <ogc:Touches />
		  <ogc:Within />
		  <ogc:Overlaps />
		  <ogc:Crosses />
		  <ogc:Intersect />
		  <ogc:Contains />
		  <ogc:DWithin />
		  <ogc:BBOX />
		 </ogc:Spatial_Operators>
		 </ogc:Spatial_Capabilities>
		- <ogc:Scalar_Capabilities>
		  <ogc:Logical_Operators />
		- <ogc:Comparison_Operators>
		  <ogc:Simple_Comparisons />
		  <ogc:Like />
		  <ogc:Between />
		 </ogc:Comparison_Operators>
		 </ogc:Scalar_Capabilities>
		 </ogc:Filter_Capabilities>
		 </WFS_Capabilities>
		(The LatLongBoundingBox in this case is obviously not in units of LatLon but represent the boundingbox in the offered SRS 25832. This seems to be strange since thes doesn' t occur in the WMS-capabilities document. In this document the LatLongBoundingBox und the BoundingBox in the source SRS are both all right.)
		I even tried different versions of MapServer and I discovered a slight difference with other versions. If I change my datasource from PostGIS to OGR/MapInfo Tab former versions of MapServer (5.4.2/5.2.3) provide features as well. But just in case of OGR/MapInfo Tab - not with PostGIS in use! As I have to use PostGIS I'm interested in any hints to solve this problem.
		Therefore I would be glad to hear from you!
		Thanks so far and best regards!
		Andreas
		Mit freundlichen Grüßen
		Im Auftrag
		Andreas Fischer
		Kreis Unna - Der Landrat
		Friedrich-Ebert-Straße 17
		59425 Unna
		Fon 02 3 03 27-44 16
		Fax 0 23 03 27-28 96
		andreas.fischer at kreis-unna.de
		www.kreis-unna.de
		Diese E-Mail wurde beim Ausgang auf Viren geprueft. Wegen der potentiellen Gefahr auf den Uebertragungswegen wird zu einer Vireneingangskontrolle geraten. Eine Haftung für Virenfreiheitwird ausgeschlossen.
		mapserver-users mailing list
		http://lists.osgeo.org/mailman/listinfo/mapserver-users
	Assefa Yewondwossen
	Software Analyst
	Email: yassefa at dmsolutions.ca
	http://www.dmsolutions.ca/
	Phone: (613) 565-5056 (ext 14)
	Fax:   (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101123/4517f741/attachment-0001.html
