[mapserver-users] SLD and OUTPUTFORMAT compatibility?
Martin Ouellet geomartino at gmail.com
Tue Nov 23 10:38:43 EST 2010
Hi Assafa, thanks for your quick reply
I'am working with mapserver 5.6.5 (installed form elgis RPM -
http://wiki.osgeo.org/wiki/Enterprise_Linux_GIS)
Here the requested files:
I've prefix the files with "aggpng_working" of identify the working example
1) aggpng_working_mapserv.log (log of mapserver for this case only)
2) the working scenario generate 2 mapfile:
aggpng_working_4cebdca9_13c_2._sld.map
aggpng_working_4cebdca9_13f_2._sld.map
I've prefix the files with "gdpng_notworking" to identify the case who's not
working
3) gdpng_notworking_mapserv.log (log of mapserver for this case only)
4) gdpng_notworking_4cebdbff_7fc0_2._sld.map
Thanks again...
MartinO
2010/11/23 Yewondwossen Assefa <yassefa at dmsolutions.ca>
>  Hi Martin,
>  Can you try to check the map file after the sld has been applied: you can
> do that by setting your map file in debug and checking the log file  look
> for something like "...Map file after SLD was applied"  (ex: something like
> this):
> CONFIG  "MS_ERRORFILE" "f:/msapps/gmap-ms40/htdocs/gmap.log"
> DEBUG 5
> We can then check why the same style setting is not drawing the same way
> with the 2 drivers.  Please also indicate which version of MapServer you are
> using.
> regards,
> On 23/11/2010 9:15 AM, Martin Ouellet wrote:
> Hi all,
>  I have 2 two differents settings for symbolize my lines (refer to SLD
> settings below):
>  1) a dashed line which is working *only when I specify the outputformat:
>   *DRIVER "*GD*/PNG"
> **Note that with the driver GD/PNG, the external graphic below is not
> working but the symbol (ico-ulaval-flag.gif) is copied locally in the
> /ms_tmp directory.
> It seem to be ignored by mapserver (but raising no error)...
>  2) a external graphic which is working *only when I specify the
> outputformat:  *DRIVER "*AGG*/PNG"
>  Q: Is there a way/config to support both at the same time?
>  any advice?
>  Thanks you in advance!
>  MartinOuellet
>  SLD settings:
> ______________________________________________________________________________________
>  <!--line with a dashed pattern->
>  <se:LineSymbolizer>
>   <se:Stroke>
>     <sld:CssParameter name="stroke">#000A99</sld:CssParameter>
>     <sld:CssParameter name="stroke-dasharray">6.0 2.0 1.0 2.0 1.0 2.0 1.0
> 2.0 4.0</sld:CssParameter>
>     <sld:CssParameter name="stroke-width">1.0</sld:CssParameter>
>   </se:Stroke>
> </se:LineSymbolizer>
>  <!--line with a external graphic symbol->
>  <se:LineSymbolizer>
>   <se:Stroke>
>      <se:GraphicStroke>
>       <se:Graphic>
>         <ExternalGraphic>
>    <OnlineResource xlink:type="simple" xlink:href="
> http://www.fsi.ulaval.ca/typo3conf/ext/Annuaire_facultaire/images/ico-ulaval-flag.gif
>    <Format>image/gif</Format>
>  </ExternalGraphic>
>         <Size>10.0</Size>
>     </se:Graphic>
>   </se:GraphicStroke>
>   </se:Stroke>
> mapserver-users mailing listmapserver-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca    http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101123/692fdda0/attachment-0001.html
