[mapserver-users] querying to getting bounding box coordinates
David Hildebrand David.Hildebrand at afsc.ca
Tue Nov 23 15:48:39 EST 2010
I am running a WMS service with Mapserver in a Windows environment.  I
want to be able to run a non-spatial query on a parcel layer to return
the bounding box (in re-projected coordinates) for a particular parcel.
The bounding box and projection will then be used in a WMS query to
return a map image.
I've never coded server-side functionality with Mapserver so any
suggestions would be welcome.
Thanks to all.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
