[mapserver-users] configuring WCS
David Hildebrand David.Hildebrand at afsc.ca
Wed Nov 24 18:27:09 EST 2010
Thanks, Frank.  The documentation states that they values are
comma-separated but for WMS and WFS they are space-delimited.  The
documentation needs to be changed.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Wednesday, November 24, 2010 2:59 PM
To: David Hildebrand
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] configuring WCS
David Hildebrand wrote:
> I am trying to configure a WCS service but when I do a GetCapabilities
I
> get the following error.
> msOWSGetLayerExtent(): WMS server error. Wrong number of arguments for
> EXTENT metadata.
> I have wcs_extent defined for all the layers but nowhere in the
> MapServer documentation can I find that the WEB>METADATA tag requires
> extent to be defined.  I have WMS and WFS services running and there
> seems to be no problem with the configuration.
David,
The *_extent metadata item needs four space separated values in the
value string - minx miny maxx maxy.  I presume you don't have it setup
properly.
It may well be that the WMS and WFS services don't actually use the
extent
so the WCS service is the first thing to error out.  It is unfortunate
about
it being reported as a WMS error, but at that level of the code it is
hard
to know the context of the request.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
