[mapserver-users] wfs different level of detail
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Nov 29 03:54:06 EST 2010
If you data are in a database it should be possible to take them out through simplify function. For PostGIS see http://postgis.refractions.net/docs/ST_Simplify.html
You should define the layer DATA in the mapfile with simplifying factor as a variable and then make OpenLayers to send the value as an extra parameter with GetFeature requests.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Daniel Carvalho
> Lähetetty: 28. marraskuuta 2010 17:14
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] wfs different level of detail
> hi
> When I'm using WFS with OpenLayers, is it possible to make mapserver
> produce different detail level (simplifying geometries)
> according to the
> zoom level I'm using?
> That would be convenient to display maps with a lot of detail..
> Or I should define different layers, with different details, and
> activate one of then according to the zoom level?
> thks!
