[mapserver-users] Re: Raster Data from PostGIS
Carlos Ruiz boolean10001 at yahoo.com
Mon Nov 29 10:58:35 EST 2010
Hi Florencia,
You just can show a layer per LAYER section at a time. However, you can use the
GROUP label within each
LAYER section of each raster you want to show, to turn on/off all those layers.
Solo puedes mostrar una capa por cada sección LAYER a la vez. Sin embargo,
puedes hacer uso de la
etiqueta GROUP dentro de cada sección LAYER a cada uno de los archivos raster
que quieras mostrar para
encenderlos o apagarlos en grupo.
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Mon, November 29, 2010 9:50:35 AM
Subject: [mapserver-users] Re: Raster Data from PostGIS
Hi Carlos,
Thanks for your response.
Ok, but I want to show only one layer with some rasters (more than one). I
can save tif files into my system (directory into my hard disc instead of
PostGIS), but I am thinking about can show a layer with more than one tif
raster.
Any ideas?
Thanks a lot!
Florencia from Uruguay
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Raster-Data-from-PostGIS-tp5784362p5784801.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101129/daec8adf/attachment.html
