[mapserver-users] MapServer Resolution - how to set the parameter dynamically
Astrid Emde astrid.emde at wheregroup.com
Tue Oct 5 03:41:07 EDT 2010
Hello list,
I tested the new Parameter
With these Paramter I can produce a nice map for print output [1].
It would be nice to set the Paramter RESOLUTION parameter directly in the
MapRequest like &RESOLUTION=288. If not set here the default from the
Mapfile could be used.
What do you think about this idea? Do you have discussed this already?
Alternatively I tried to set a variable wit MapServer variable
substitution [2] like:
RESOLUTION %resolution%
But this caused a MapServer error.
If someone has already a solution to set the resolution dynamically
(without MapScript) please let me know.
Astrid Emde
[1] http://mapserver.org/development/rfc/ms-rfc-55.html
[2] http://mapserver.org/mapfile/variable_sub.html
