[mapserver-users] WMS Request for a single point?
Robert Hicks
robhyx at gmail.com
Tue Oct 12 09:06:17 EDT 2010
Ok after some sleuthing, I'm going to assume the bounding box of the
image is that specified in the map file. Is there a way to specify it
in the call?
Also so more immediate questions: What kind of request is this? Is
there a spec available? I'm really only used to GetMap requests so
this is a little new to me.
On Fri, Oct 8, 2010 at 2:30 PM, Robert Hicks <robhyx at gmail.com> wrote:
> Ok great! So that gave me an image with a push pin on it. So here is
> another question: what is the bounding box of the requested image, and
> can I specify it? I need to be able to merge this image together with
> another GeoTiff (preferably using gdalmerge) so that the point lands
> on the same geographic location in the base image. The original image
> is in EPSG 4326, and I'm not sure what units of measurement this call
> is using. I tried requesting the point layer as a tif but I think it
> just gave me a regular non geotiff, which is fine because I can update
> the header using gdal_translate but I need to know the bounding box in
> 4326.
> On Fri, Oct 8, 2010 at 12:41 PM, Lime, Steve D (DNR)
> <Steve.Lime at state.mn.us> wrote:
>> I think you need:
>> &mapsize=1000+500
>> Or set it in the mapfile and mapserver will use that.
>> Steve
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Robert Hicks
>> Sent: Friday, October 08, 2010 11:40 AM
>> To: Fawcett, David (MPCA)
>> Cc: mapserver-users at lists.osgeo.org
>> Subject: Re: [mapserver-users] WMS Request for a single point?
>> Great, thanks for all the help everyone! I tried that command:
>> http://10.0.11.54:8008/cgi-bin/mapserv.exe?map=/ms4w/apps/ms_ogc_workshop/client/wms/reference.map&mode=map&map_layer[0]=FEATURE+POINTS+270000+696000+END+END&WIDTH=1000&HEIGHT=500
>> (I had to change a few things), and I get this error:
>> "msDrawMap(): Image handling error. Unable to initialize image.
>> msPrepareImage(): General error message. Image dimensions not
>> specified. msCalculateScale(): General error message. Invalid image
>> width or height. "
>> Any ideas?
>> On Fri, Oct 8, 2010 at 12:14 PM, Fawcett, David (MPCA)
>> <David.Fawcett at state.mn.us> wrote:
>>> This example works: http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/offset.map&mode=map&map_layer[0]=FEATURE+POINTS+270000+696000+END+END
>>> You can access your layer through the layer name or it's (zero-based) index.
>>> The simple example layer is below with a simple circle symbol defined in the map file.
>>> LAYER
>>> NAME 'singlepoint'
>>> TYPE point
>>> STATUS DEFAULT
>>> CLASS
>>> STYLE
>>> COLOR 255 0 0
>>> SIZE 15
>>> symbol "circle"
>>> END
>>> END
>>> END
>>> SYMBOL
>>> NAME "circle"
>>> TYPE ellipse
>>> FILLED true
>>> POINTS
>>> 1 1
>>> END
>>> END
>>> Sent: Friday, October 08, 2010 11:07 AM
>>> To: thomas bonfort
>>> Ok, that looks extremely promising. I'm going to go ahead and try it
>>> on my local Mapserver.
>>> On Fri, Oct 8, 2010 at 12:03 PM, thomas bonfort
>>> <thomas.bonfort at gmail.com> wrote:
>>>> have a look at http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05881.html
>>>> the syntax for cgi commands has changed since then, you'd have to use
>>>> something like
>>>> &map.layer[site]=feature+points+582248.23+4841497.11+end+end
>>>> or &map.layer[site].feature.points=582248.23+4841497.11
>>>> (I cant remember what syntax is correct)
>>>> regards,
>>>> thomas
>>>> On Fri, Oct 8, 2010 at 17:10, Robert Hicks <robhyx at gmail.com> wrote:
>>>>> Hello all! Ok, this is probably a long shot but, is there a way to
>>>>> request an image from Mapserver that is just a point? The idea is I
>>>>> have another larger (reference) map image and I want to place a push
>>>>> pin on top of it in a specified point. It has to be a WMS call so that
>>>>> I can take the image and merge it with the other larger map into one
>>>>> so that it can be put into a PDF. Any help would be appreciated.
>>>>> Thanks!
>>>>> web http://www.hyxspace.com
>>>>> aim hyx1138
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> aim hyx1138
>> aim hyx1138
> aim hyx1138
aim hyx1138
