Hi: [mapserver-users] MapServer as a reprojecting WMS proxy,
is it possible?
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Oct 13 16:44:18 EDT 2010
I can't test right now but I suppose this should work. Define the LAYER to use the SRS supported by the remote service like in the document http://mapserver.org/ogc/wms_client.html
LAYER
NAME "country_bounds"
TYPE RASTER
STATUS ON
CONNECTION "http://demo.mapserver.org/cgi-bin/wms?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "country_bounds"
"wms_server_version" "1.1.1"
"wms_format" "image/gif"
END
END
Then use the MAP-WEB-METADATA just as you did and your server should advertise only EPSG:3003 out.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Niccolo Rigacci
Lähetetty: ke 13.10.2010 22:48
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] MapServer as a reprojecting WMS proxy,is it possible?
There is a WMS server providing EPSG:4326, but I need a WMS
server providing EPSG:3003.
So I tried to configure MapServer to act as a proxy (both client
and server), doing the reprojection. But I failed.
I tried something like this:
MAP
PROJECTION
'init=epsg:3003'
END
WEB
METADATA
'ows_srs' 'EPSG:3003'
END
END
LAYER
PROJECTION
'init=epsg:4326'
END
METADATA
'wms_srs' 'EPSG:4326 EPSG:3003'
END
END
END
As a server, it announces both EPSG:4326 and EPSG:3003, but if I
ask for EPSG:3003, it uses the same SRS when acting as a client.
If I put just EPSG:4326 into LAYER.METADATA.wms_srs, the server
does not announce EPSG:3003.
What can I do?
Thanks!
Niccolo Rigacci
Firenze - Italy
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
