[mapserver-users] Re: Compiling in Visual Studio 2008
Tamas Szekeres
szekerest at gmail.com
Thu Oct 14 15:22:14 EDT 2010
You could also use the SDK packages from http://vbkto.dyndns.org/sdk/
These packages provide a Makefile to do a commandline build by using the
Visual Studio Command Prompt.
In order to integrate this into a solution the easiest thing to do is to
create a VC++ makefile project and set up the build command line according
to the Makefile provided.
You could also create a debug build by adding 'DEBUG=YES' to the build
command line.
Best regards,
Tamas
2010/10/14 Frost89 <kristian_frost7 at hotmail.com>
> Hi Sumit
> Thanks for the answer. I'm a newbee at anything thats not .NET, but this
> solution would really help in a project I'm on. Do you know anywhere I can
> read more about setting up/creating this project? Or can you post an
> example
> if it's not too complicated?
> /Kristian Frost
> http://osgeo-org.1803224.n2.nabble.com/Compiling-in-Visual-Studio-2008-tp5634683p5634893.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101014/8441fc30/attachment.html
