[mapserver-users] Problem with wfs.php
Richard LEHAUT
richard.lehaut at gmail.com
Thu Oct 14 16:18:53 EDT 2010
Thanks for example.
I solved problem. Thanks every body. Here, my code test :
Richard LEHAUT/Tiolebucheron
<?php
$list_layer= array();
$list_layer[]='<?xml version="1.0" encoding="utf-8"?><GetFeature xmlns="
http://www.opengis.net/wfs" xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:gml="
http://www.opengis.net/gml" service="WFS" version="1.0.0"
outputFormat="GML2" maxFeatures="100" handle="" ><Query
typeName="ZNIEFF_de_type_1" srsName="EPSG:2154"
><ogc:Filter><Intersect><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>((402363.90165238
2464262.4974283,481033.30361535 2524234.6872655,513841.61923219
2464615.2750155,433055.55174556 2416637.5231457,402363.90165238
2464262.4974283))</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersect></ogc:Filter></Query></GetFeature>';
foreach($list_layer as $i => $layer) {
echo $layer;
$curl_init[$i]= curl_init('
http://ws.carmen.developpement-durable.gouv.fr/WFS/8/nature?');
curl_setopt($curl_init[$i], CURLOPT_CONNECTTIMEOUT, 30);
curl_setopt($curl_init[$i], CURLOPT_TIMEOUT, 30);
curl_setopt($curl_init[$i], CURLOPT_POST,1);
curl_setopt($curl_init[$i], CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl_init[$i], CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($curl_init[$i], CURLOPT_HEADER, 0);
curl_setopt($curl_init[$i], CURLOPT_HTTPHEADER, array('Content-Type:
text/xml'));
curl_setopt($curl_init[$i], CURLOPT_POSTFIELDS, $layer);
curl_setopt($curl_init[$i], CURLOPT_RETURNTRANSFER, 1);
$curl_multi = curl_multi_init();
curl_multi_add_handle($curl_multi, $curl_init[$i]);
do {
curl_multi_exec($curl_multi, $running);
} while($running > 0);
echo curl_multi_getcontent($curl_init[$i]);
curl_close($curl_init[$i]);
return $list_layer;
2010/10/13 Olivier BEDEL <o.bedel at alkante.com>
> Hi Robert,
> The file_get_contents error you get doesn't come from your code but is
> return by the Carmen wfs server.
> As Jukka said, your filter seems too long to be sent in a GET parameter.
> But when querying the wfs server in POST, you should send your query in XML
> and not use Key Value Pair encoding (FILTER=...).
> In fact, the content of your POST query should look like this :
> ><ogc:Filter><Intersect><PropertyName>Geometry</PropertyName><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>(526467,6821671
> 526471,6821675 526480,6821677 526482,6821676 526491,6821679 526490,6821682
> 526546,6821697 526615,6821701 526616,6821699 526627,6821699 526628,6821702
> 526708,6821705 526804,6821709 526821,6821701 526886,6821665 526916,6821658
> 526933,6821616 526961,6821574 526969,6821565 526982,6821513 526833,6821533
> 526833,6821517 526813,6821513 526801,6821508 526749,6821480 526732,6821469
> 526718,6821484 526688,6821481 526616,6821481 526620,6821448 526584,6821438
> 526547,6821401 526545,6821397 526533,6821376 526455,6821381 526453,6821379
> 526409,6821377 526415,6821415 526429,6821499 526440,6821569 526377,6821567
> 526362,6821463 526357,6821393 526359,6821371 526360,6821362 526365,6821332
> 526325,6821292 526315,6821308 526302,6821322 526296,6821325 526277,6821347
> 526286,6821417 526286,6821447 526295,6821516 526303,6821549 526308,6821569
> 526314,6821571 526320,6821578 526328,6821580 526340,6821589 526381,6821619
> 526466,6821673 526467,6821671 526467,6821671) (526489,6821639 526492,6821655
> 526493,6821655 526489,6821639 526489,6821639) (526467,6821588 526466,6821586
> 526464,6821585 526467,6821588 526467,6821588) (526479,6821603 526478,6821601
> 526477,6821599 526479,6821603 526479,6821603) (526489,6821639 526489,6821639
> 526486,6821627 526489,6821639 526489,6821639)) ((527187,6822859
> 527158,6822860 527138,6822862 527110,6822871 527104,6822873 527098,6822871
> 527054,6822879 527003,6822885 526998,6822885 526995,6822885 526972,6822882
> 526964,6822889 526955,6822894 526935,6822910 526922,6822929 526916,6822946
> 526910,6822973 526917,6822980 526917,6822987 526915,6823010 526942,6823015
> 526943,6823045 526945,6823052 526948,6823056 526956,6823059 526969,6823073
> 526973,6823081 526975,6823094 526970,6823097 526971,6823102 526987,6823123
> 527004,6823131 527019,6823103 527050,6823109 527134,6823120 527137,6823099
> 527133,6823084 527134,6823050 527190,6823074 527199,6823016 527220,6823014
> 527213,6822861 527204,6822860 527187,6822859 527187,6822859) (527114,6823008
> 527114,6823001 527071,6822980 527059,6822982 527050,6822978 527032,6822968
> 527024,6823072 527047,6823070 527043,6823034 527049,6822983 527068,6822984
> 527114,6823008 527114,6823008) (527112,6822930 527115,6822933 527118,6822943
> 527118,6822947 527119,6822955 527124,6822954 527123,6822945 527119,6822930
> 527115,6822925 527112,6822930 527112,6822930)) ((526685,6821896
> 526737,6821974 526766,6822042 526771,6822072 526782,6822030 526808,6821981
> 526869,6821901 526875,6821889 526909,6821797 526908,6821779 526900,6821771
> 526832,6821727 526812,6821722 526787,6821720 526785,6821761 526666,6821870
> 526685,6821896 526685,6821896)) ((527009,6822654 527076,6822645
> 527077,6822629 527076,6822611 527076,6822608 527079,6822589 527070,6822587
> 527063,6822589 527038,6822623 527012,6822641 527009,6822649 527007,6822650
> 527002,6822652 526984,6822657 526953,6822666 526917,6822684 526898,6822697
> 526901,6822703 526949,6822680 526958,6822701 526927,6822716 526946,6822718
> 526955,6822714 526961,6822709 526980,6822748 526988,6822809 526997,6822811
> 527002,6822843 527040,6822877 527052,6822875 527086,6822868 527100,6822860
> 527104,6822849 527107,6822845 527113,6822839 527120,6822826 527134,6822803
> 527147,6822771 527160,6822720 527168,6822679 527153,6822679 527132,6822678
> 527079,6822677 527012,6822671 527009,6822654 527009,6822654))
> ((527249,6822166 527250,6822157 527257,6822142 527274,6822104 527280,6822079
> 527265,6822097 527230,6822148 527205,6822195 527179,6822230 527163,6822262
> 527205,6822288 527251,6822297 527270,6822298 527334,6822298 527376,6822304
> 527391,6822304 527503,6822328 527554,6822333 527572,6822322 527548,6822299
> 527542,6822296 527545,6822281 527391,6822246 527282,6822211 527218,6822199
> 527249,6822166 527249,6822166)) ((526821,6822064 526901,6822093
> 526939,6822084 526962,6822085 526985,6822075 527018,6822113 527046,6822155
> 527068,6822140 527064,6822093 527061,6822073 527051,6822041 527024,6821996
> 526906,6821995 526896,6821998 526889,6822002 526868,6822015 526852,6822029
> 526821,6822064 526821,6822064)) ((527082,6822584 527086,6822573
> 527091,6822566 527073,6822564 527065,6822561 527046,6822526 527047,6822455
> 527052,6822410 527053,6822381 527038,6822382 527036,6822378 526966,6822403
> 526967,6822435 526972,6822476 526983,6822538 527010,6822639 527032,6822623
> 527036,6822619 527055,6822594 527060,6822586 527066,6822584 527081,6822585
> 527082,6822584 527082,6822584)) ((526546,6821979 526549,6822025
> 526551,6822040 526563,6822075 526684,6822011 526655,6821986 526614,6821947
> 526680,6821898 526664,6821872 526662,6821873 526546,6821979 526546,6821979))
> ((527014,6821959 527090,6821938 527116,6821929 527112,6821927 527110,6821928
> 527103,6821924 527104,6821920 527060,6821893 527019,6821865 527017,6821866
> 527006,6821858 527008,6821855 526927,6821792 526923,6821792 526922,6821794
> 526924,6821803 526984,6821906 527006,6821947 527014,6821959 527014,6821959))
> ((527170,6822232 527134,6822195 527134,6822164 527129,6822155 527102,6822120
> 527073,6822133 527074,6822170 527083,6822210 527123,6822234 527156,6822262
> 527170,6822232 527170,6822232)) ((526582,6822099 526581,6822099
> 526584,6822100 526592,6822098 526600,6822099 526626,6822130 526741,6822056
> 526740,6822052 526704,6822025 526582,6822099 526582,6822099))
> ((527461,6822398 527434,6822522 527484,6822557 527504,6822464 527472,6822443
> 527472,6822435 527489,6822377 527461,6822398 527461,6822398))
> ((527423,6822716 527345,6822691 527339,6822710 527302,6822693 527289,6822721
> 527396,6822770 527414,6822736 527423,6822716 527423,6822716))
> ((527726,6822272 527788,6822255 527792,6822219 527799,6822180 527817,6822133
> 527792,6822152 527774,6822172 527747,6822196 527727,6822269 527726,6822272
> 527726,6822272)) ((527835,6823091 527845,6823121 527847,6823122
> 527871,6823117 527904,6823102 527896,6823091 527911,6823082 527889,6823053
> 527858,6823079 527835,6823091 527835,6823091)) ((527129,6822598
> 527125,6822597 527154,6822653 527171,6822677 527210,6822631 527129,6822598
> 527129,6822598)) ((527184,6822670 527176,6822681 527190,6822695
> 527236,6822770 527269,6822749 527184,6822670 527184,6822670))
> ((526719,6821400 526751,6821412 526776,6821372 526747,6821327 526719,6821400
> 526719,6821400)) ((527143,6822790 527141,6822795 527133,6822810
> 527128,6822819 527124,6822825 527117,6822840 527110,6822846 527107,6822851
> 527103,6822862 527106,6822865 527110,6822865 527139,6822859 527135,6822836
> 527160,6822831 527174,6822853 527177,6822854 527187,6822855 527164,6822818
> 527143,6822790 527143,6822790)) ((527423,6822716 527420,6822725
> 527449,6822734 527480,6822692 527430,6822672 527428,6822676 527431,6822697
> 527423,6822716 527423,6822716)) ((526654,6822160 526675,6822186
> 526685,6822193 526698,6822175 526692,6822165 526679,6822144 526654,6822160
> 526654,6822160)</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersect></ogc:Filter></Query></GetFeature>
> Regards,
> Olivier.
> ----- Mail Original -----
> De: "Richard LEHAUT" <richard.lehaut at gmail.com>
> À: "Yves Jacolin" <yves.jacolin at camptocamp.com>
> Cc: "Rahkonen Jukka" <Jukka.Rahkonen at mmmtike.fi>,
> mapserver-users at lists.osgeo.org
> Envoyé: Mardi 12 Octobre 2010 16:59:49
> Objet: Re: [mapserver-users] Problem with wfs.php
> Hi,
> I followed your instructions, I try use "curl-setopt-array" with
> "curl_multi_init".
> function curl_get_multi_content($list_layer) {
> $curl_init = array();
> unset($options);
> $options = array
> CURLOPT_RETURNTRANSFER => true,
> CURLOPT_CONNECTTIMEOUT => 120,
> CURLOPT_TIMEOUT => 120,
> CURLOPT_POST => 1,
> CURLOPT_POSTFIELDS => $layer['data'].$layer['filter'],
> $curl_init[$i] = curl_init($layer['url']);
> curl_setopt_array($curl_init[$i],$options);
> do {
> $list_layer[$i] =
> $layer+Array('info'=>get_info_xml(curl_multi_getcontent($curl_init[$i]),
> $layer['name']));
> return $list_layer;
> With my server, result is correct. I've a error with server Carmen :
> ZNIEFF_de_type_1=======>
> Warning: file_get_contents(
> http://ws.carmen.developpement-durable.gouv.fr/cgi-bin/mapserv?service_idx=8&map=%2Fmnt%2Fdata_carmen%2FBN%2FPublication%2Fwms_nature.map&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=ZNIEFF_de_type_1&FILTER=%3CFilter%3E%3CIntersect%3E%3CPropertyName%3EGeometry%3C%2FPropertyName%3E%3Cgml%3APolygon%3E%3Cgml%3AouterBoundaryIs%3E%3Cgml%3ALinearRing%3E%3Cgml%3Acoordinates%3E%28526467%2C6821671%20526471%2C6821675%20526480%2C6821677%20526482%2C6821676%20526491%2C6821679%20526490%2C6821682%20526546%2C6821697%20526615%2C6821701%20526616%2C6821699%20526627%2C6821699%20526628%2C6821702%20526708%2C6821705%20526804%2C6821709%20526821%2C6821701%20526886%2C6821665%20526916%2C6821658%20526933%2C6821616%20526961%2C6821574%20526969%2C6821565%20526982%2C6821513%20526833%2C6821533%20526833%2C6821517%20526813%2C6821513%20526801%2C6821508%20526749%2C6821480%20526732%2C6821469%20526718%2C6821484%20526688%2C6821481%20526616%2C6821481%20526620%2C6821448%20526584%2C6821438%20526547%2Cin /applications/www/carmen/WFS/wfs.php on line 123
> Warning: Cannot modify header information - headers already sent by (output
> started at /applications/www/carmen/WFS/wfs.php:123) in
> /applications/www/carmen/WFS/wfs.php on line 91.
> It's the same message of the first error (number of ligne changed), but the
> function working properly on my server!!!!
> Thanks for your help.
> 2010/10/11 Yves Jacolin < yves.jacolin at camptocamp.com >
> Hi,
> Don't use file_get_contents but cURL rather:
> http://www.php.net/manual/fr/function.curl-setopt-array.php
> Regards,
> Y.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101014/d62f34f8/attachment-0001.html
