[mapserver-users] Trouble shooting SLD?
K
ken at sandnarrows.com
Sun Oct 17 17:21:51 EDT 2010
Yes I do, in case it was a problem with the field I went and tried
SHAPE, FID, ID and the rest of the fields, no change. On the odd case I
spelt Communities wrong I also went through and copy and pasted from
once source all the times I had put it in my MAP and SLD document.
All same result unfortunately, still not using the SLD.
Thanks for your time in providing suggestions.
Ken
On 17/10/2010 5:03 PM, Rahkonen Jukka wrote:
> Hi,
> This is a plain guess, but do you have an attribute named "Communities" in your data as it is used in
> <PropertyName>Communities</PropertyName>?
> -Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: K
> Lähetetty: su 17.10.2010 21:37
> Vastaanottaja: Rahkonen Jukka
> Kopio: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Trouble shooting SLD?
> Ok, didnt want to spam the the list, here is my map file and the SLD
> file I am using:
> MAP
> NAME "Communities"
> SIZE 700 500
> UNITS meters
> CONFIG PROJ_LIB "R:\proj\nad\"
> CONFIG MS_ERRORFILE "mapserver.log"
> DEBUG 5
> EXTENT -12726256 6595213 -12674715 6655243
> PROJECTION
> "init=epsg:900913"
> END
> TRANSPARENT ON
> IMAGECOLOR 255 255 255
> IMAGEQUALITY 95
> IMAGETYPE png
> OUTPUTFORMAT
> NAME png
> DRIVER 'GD/PNG'
> MIMETYPE 'image/png'
> #IMAGEMODE PC256
> EXTENSION 'png'
> END
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> WEB
> IMAGEPATH 'R:/webtemp/'
> IMAGEURL '/webtemp/'
> # WMS server settings
> METADATA
> 'wms_title' '"Communities"'
> 'wms_onlineresource'
> 'http://someserver.com/cgi-bin/mapserv?map=wms.map&'
> 'wms_srs' 'EPSG:900913'
> END
> END
> LAYER
> NAME 'Communities'
> TYPE POLYGON
> DATA 'someshapefile.shp'
> TEMPLATE 'ttt_query.html'
> DUMP TRUE
> METADATA
> 'wms_title' 'Communities'
> 'wms_include_items' 'ID'
> END
> STATUS DEFAULT
> CLASS
> NAME 'Communities'
> STYLE
> SYMBOL 'circle'
> SIZE 3
> OUTLINECOLOR 255 255 0
> END
> END
> END
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> FILLED TRUE
> POINTS 1 1 END
> END
> END
> And the SLD file:
> <StyledLayerDescriptor version="1.0.0">
> <NamedLayer>
> <Name>Communities</Name>
> <UserStyle>
> <Title>Communities</Title>
> <FeatureTypeStyle>
> <Rule>
> <PolygonSymbolizer>
> <Geometry>
> </Geometry>
> <Fill>
> <CssParameter name="fill">#ff0000</CssParameter>
> </Fill>
> <Stroke>
> <CssParameter name="stroke">#ff0000</CssParameter>
> <CssParameter name="stroke-width">2.0</CssParameter>
> </Stroke>
> </PolygonSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> Thanks for your help,
> Ken
> On 17/10/2010 3:16 PM, Rahkonen Jukka wrote:
>> Hi,
>> It would be much easier to start thinking about what goes wrong if you could mail also your layer and the failing SLD.
>> -Jukka Rahkonen-
>> Lähetetty: su 17.10.2010 21:09
>> Vastaanottaja: Jeff McKenna
>> Thanks, I tried one of those. Left colors as is, but changed the Name,
>> Title and PropertyName fields to the name of the layer in my map file.
>> Still no luck, just returns the normal map.
>> Thanks again,
>> Ken
>> On 17/10/2010 11:57 AM, Jeff McKenna wrote:
>>> On 10-10-17 11:01 AM, K wrote:
>>>> Is there any way to trouble shoot why an SLD layer is being being
>>>> rejected, or suggestions as to what it might be? Currently Mapserver
>>>> seems to be ignoring the SLD and not displaying it, which I assume means
>>>> some kind of parsing error or rejection of the SLD?
>>>> I look at my getcapabilities and it says:<UserDefinedSymbolization
>>>> SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
>>>> Which I assume means yes SLD is supported.
>>>> I can browse to my SLD file, no errors opening it:
>>>> http://www.rockies.ca/coyotes/sld_template2.xml
>>>> I have tried using an SLD created by QGIS, one using PHP/Mapscript, and
>>>> a couple from examples in Mapserver documentation that I edited to work
>>>> for my use.
>>>> I turned on the error log in my map file and put debug to 5, no mention
>>>> of any errors or anything, though that isn't surprising as from what I
>>>> read Mapserver currently catches those errors and displays the WMS layer
>>>> as is, but provides no feedback as to the errors?
>>>> I had spaces in my layer name to start, thought that might cause a
>>>> problem so removed those.
>>>> I have tried viewing in Openlayers, straight URL request, and via a
>>>> quick mapscript application, all the same result.
>>>> Any other suggestions?
>>> Note that all SLDs used in the MapServer documentation can be accessed
>>> at: http://demo.mapserver.org/ogc-demos/map/sld/
>>> -jeff
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
