[mapserver-users] Re: UK Ordnance Survey MasterMap Cartographic
Text orientation display problem
DonaldKerr
donald.kerr at dkerr.co.uk
Mon Oct 18 14:49:58 EDT 2010
Jez,
Is the following code of any use?
orientation definitely works in this way as does height. I am currently
working on getting the color from PostGIS too - I am testing it just now.
Will be looking at how to specify to font and the correct position based on
the database as well.
Regards,
Donald
DATA "geom FROM (SELECT toid, featurecode, textstring, height*4 AS height,
orientation/10 AS orientation, substring(col,0,2)|| ' ' ||
substring(col,2,2) || ' ' || substring(col,4,2) AS oscolor, fontnumber,
anchorposition, textstyle, geom FROM cartographictext) AS foo USING UNIQUE
toid"
CLASS
# Tidal Water
EXPRESSION ([featurecode] = 10204)
LABEL
TYPE truetype
FONT arial
SIZE [height]
MAXSIZE 21
MINSIZE 4
POSITION cc
#COLOR 0 153 255
COLOR [oscolor]
ANTIALIAS TRUE
ANGLE [orientation]
FORCE TRUE
END # LABEL
END # CLASS
View this message in context: http://osgeo-org.1803224.n2.nabble.com/UK-Ordnance-Survey-MasterMap-Cartographic-Text-orientation-display-problem-tp5293281p5648192.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
