[mapserver-users] PHP mapscript: Custom rectangles overlay
mani2604
mani2604 at gmail.com
Tue Oct 19 04:47:08 EDT 2010
Hi there:
Well as u cud see in the image below... we wer trying to
have a custom rectangles overlay the base map... When we provided the
bounding box coordinates directly in the form of multidimensional array;
sort of like hard-coded them... everything is well and cool..
Now We r trying to assign check boxes to every array sort of like
user can select/deselect his choice of rectangles..So all we did was to
change the " GetRect() Function "... Although both the old & new edited
functions yield the same output when I var_dump ($qresult); bt somehow this
time the rectangles doesnt appear.. I tweaked the code but no success yet..
hoping sumone cud have a look & point out the error...!!@
CheckBox php Code :-
<?php
session_start();
// GetRect - returns array containing store table
$script_name = "index3.php";
$table = array(
array('id','state','lat_hi','long_hi','lat_low','long_low'), //field names
array(1,'andaman',13.59,94,06.73,92.53),
array(2,'AP', 19.87,84.78,12.59,76.45),
array(3,'Gujarat',24.72,74.55,20.15,68.35),
array(4,'kerala' ,12.75,77.37,08.18,74.86),
array(5,'punjab' ,32.46,76.93,29.53,73.87),
function GetRect() {
if (isset($_POST['submit']))
$tab = $_POST['tab'];
$qresult = array();
foreach ($tab as $t)
$qresult[] = $table[$t];
return $qresult;
// AddPoints - add store locations to 'poi' map layer
function AddPoints ( $map, $qresult ) {
$this_layer = $map->getLayerByName('poi');
$i = 0;
foreach($qresult as $row) {
$poi[$i] = ms_newLineObj();
$shp[$i] = ms_newShapeObj(MS_SHAPE_POLYGON);
$poi[$i]->addXY($row[5],$row[4]);
$poi[$i]->addXY($row[3],$row[4]);
$poi[$i]->addXY($row[3],$row[2]);
$poi[$i]->addXY($row[5],$row[2]);
$shp[$i]->add($poi[$i]);
$shp[$i]->set(index, $row[0]);
$this_layer->addFeature( $shp[$i] );
$i++;
return;
} // end AddPoints
$map = ms_newMapObj("/ms4w/apache/htdocs/india_roads3.map");
$extent = array(62.786563, 7.392830, 102.765356, 36.151322);
$qresult = GetRect();
AddPoints( $map, $qresult );
$image=$map->draw();
$image_url=$image->saveWebImage();
CheckBox Html code
<form method="POST" name="myform2" action="action="<?php echo
$_SERVER['PHP_SELF']; ?>">
<?php
foreach ($table as $id=>$ar)
<br><input name="tab[]" type="checkbox" value="<?=$id?>">Id :
<?=$id?>, Name : <?=$ar[0]?>
<?php
<br><br><input name="submit" value="submit" type="submit">
</form>
This is the php code for GetRect() when we stored the arrays in session;
which is working fine
function GetStoreTable() {
$i=0;
$allValuesPresent=1;
if (isset($_SESSION['table'])) {
foreach ($_SESSION['table'] as $arr) {
if (! isset($arr[$i])) {
$allValuesPresent = 0;
break;
// Will get overwritten by query if any are missing
$qresult[$i]=$arr;
$i++;
return $qresult;
} // end GetStoreTable
Image:- http://osgeo-org.1803224.n2.nabble.com/file/n5650035/polygon5.jpg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/PHP-mapscript-Custom-rectangles-overlay-tp5650035p5650035.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
