[mapserver-users] Trouble shooting SLD?
K
ken at sandnarrows.com
Tue Oct 19 16:44:54 EDT 2010
Thanks again for your assistance.
The SLD file I was using was from the mapserver repository that Jeff
posted earlier in the thread. I went ahead and edited it and removed all
the differing bits from yours. No change, still not reading the SLD file.
I then decided to create a line file, in case the issue was polygons,
and use the SLD file you posted, with the only change being the name,
still not working.
I went through and changed all the names to be different, then tried
matching the SLD name with different parts in the odd hope it would
work, again no luck.
No matter what I do it seems the SLD is being ignored.
Ken
On 19/10/2010 3:52 AM, Rahkonen Jukka wrote:
> Hi,
> I have never made a single SLD file myself, just edited something
> working that I have found so unfortunately I fear I cannot give very
> good advice. I did, however, compare something that works for me and
> your SLD file and these are the differences:
> My first line has more elements:
> <StyledLayerDescriptor version="1.0.0"
> xmlns="http://www.opengis.net/sld"
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
> You have Title, I don't. Hard to believe this is critical, though
> <Title>Communities</Title>
> Then you are giving the geometry element as
> <Geometry>
> <PropertyName>Communities</PropertyName>
> </Geometry>
> I do not have that element at all. Mapserver documentation says that it
> is not supported and I also believe that now it is wrong in your SLD. I
> understand that your SLD is trying to telll now that the geometry of
> your layer is stored in a field named "Communities". By the way, it
> might be better to use different names in various places instead of
> "Communities" everywhere at least when testing.
> Geoserver folks have made a SLD cookbook
> http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/index.html
> it is probably worth reading.
> And here is the SLD that I looked at when doing comparison. I took it
> out from my working Mapserver layer with GetStyles. Perhaps you could
> try the same, style your layer to look good by editing the mapfile and
> take the SLD out with GetStyles and you should have a good template in
> your hands.
> <NamedLayer>
> <Name>maxspeed_query</Name>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <LineSymbolizer>
> <Stroke>
> <CssParameter name="stroke">#ff0000</CssParameter>
> <CssParameter name="stroke-opacity">1.00</CssParameter>
> <CssParameter name="stroke-width">3.00</CssParameter>
> </Stroke>
> </LineSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> -Jukka Rahkonen-
> K wrote
>> As I am still unable to get my SLD to work, I wonder if the
>> shape file
>> (is it a shape file?) and map file for that example is available to
>> download somewhere? This way I can toss it on my server and
>> it would let
>> me see if my problem is software related, rather then something wrong
>> with my files.
>> Thanks,
>> Ken
>> On 18/10/2010 5:31 PM, Jeff McKenna wrote:
>>> On 10-10-18 11:16 AM, Rahkonen Jukka wrote:
>>>> I noticed that none of the full request links in the document
>>>> http://mapserver.org/ogc/sld.html are working now
>>> Good catch Jukka. The examples should be working again,
>> please re-try.
>>> -jeff
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
