[mapserver-users] ESRI binary grids RRD files ?
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Oct 21 04:55:20 EDT 2010
solution:
make sure the .rrd and .aux files have exactly the same name as the folders
with the adf files. IE: in ext4 are case sensitive.
On Wed, Oct 20, 2010 at 9:13 AM, Sebastian E. Ovide <
sebastian.ovide at gmail.com> wrote:
> Frank,
> I've left those RRD and I suspect that for some reason the pyramids are not
> read... In fact the performance is very good for zoomed in views (street
> level)... but it is very slow for zoom out views (city level)... and I can
> see the IO working very hard...
> is there any way to see if MapServer/gdal is reading the pyramids correctly
> thanks
> On Tue, Oct 19, 2010 at 2:08 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
>> Sebastian E. Ovide wrote:
>>> Hi Guys,
>>> ESRI Binary grids contains a bunch of adf files and rrd files that I
>>> believe contains pyramids.
>>> Does MapServer needs those rrd files ? the question is because they are
>>> very big !
>> Sebastian,
>> Yes, MapServer will take advantage of .rrd overviews for ESRI binary
>> grids.
>> You can delete them but in some cases performance will suffer.
>> Best regards,
>> I set the clouds in motion - turn up | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush | Geospatial Programmer for Rent
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101021/631d6c0e/attachment.html
